Axlline's Fit
Old Mar 7, 2017 | 08:26 AM
SilverEX15's Avatar
Originally Posted by axlline
I did it to be different, rumor has it, that it "might" make the blade last longer, because you don't get the build up of dirt on it like you would in the oem position, but hey, to each his own Several of the 2nd gen guys have done it, I used their writeup.
I also swapped out the cabin air filter today. I am go to assume that this is the oem one from the factory, LOL!
I put K&N permanent cabin filters in our Fits.
Old Mar 7, 2017 | 08:32 AM
SilverEX15's Avatar
So my mileage on the Fit after the first month and a half was 40.9mpg(on 87). I decided to try something. So, the last two tanks, I filled up with premium(92 octane). Mileage jumped to 43.5mpg. Noticed when we bought the Fit the under engine aero cover was missing(had been ripped off). The cheapest I've found the replacement for is $149😮 You can see in the photos where the hardware was ripped away, well I had this piece of aluminum that's about the right size. Today's project, fix the"aero" hole The front 2 hole in the aluminum panel lined up perfectly, yay no drilling in the heat treated aluminum Wanted it sort of quick to remove but secure, so I made these finger that you wedge the panel in between those an the frame. I used the 2 middle holes as opposed to the original mounting spots because I could easily get to the back of these 2 holes. To remove, just remove the front two screws and pull forward(for oil changes). Had a slight gap at the front, so I took an air dam I had from the wife's old car. Reshaped it to cover the gap. Now to see if there are any mileage gains
Nice job with that aluminum plate. That plastic belly pan is the worst feature of the Fit. The sheet metal screws are okay, but the two fasteners in the rear are ridiculous. I bought several replacements, and one of them jammed the first time I used it. I'll have to make up something like you did with those swiveling clips.
Old Mar 7, 2017 | 09:55 AM
axlline's Avatar
Thanks, where I have them positioned now I don't even have to loosen or move them, just take out the front screws and pull forward to remove. I didn't think of the K&N for the cabin air filter, cool.
Old Mar 8, 2017 | 09:00 AM
axlline's Avatar
Cleaned the belly pan and took pics of what's behind it, thought you all might like to see. Also pull the heat shields, never saw a need for them. Also took pics of a few "aero" spots that I might cover
Old Mar 8, 2017 | 09:02 AM
SilverEX15's Avatar
Cleaned the belly pan and took pics of what's behind it, thought you all might like to see. Also pull the heat shields, never saw a need for them. Also took pics of a few "aero" spot that I might cover
I've had rust under there occasionally - on the bolts, etc. I clean and paint them as I see the rust. Winter isn't the best time to do that, though.
Old Mar 8, 2017 | 09:06 AM
axlline's Avatar
Yeah, I am hoping we are done with the white stuff, it was upper 60's so I wanted to play in the garage
Old Mar 8, 2017 | 09:21 AM
SilverEX15's Avatar
I've been working on projects in the garage, so the Fit has been sitting outside. : (
Old Mar 15, 2017 | 12:57 PM
Fitster C.'s Avatar
Your "Daily Driver" seems more like a life style than just a ride axlline. Very impressive work, and it looks Great!
Old Mar 15, 2017 | 09:21 PM
axlline's Avatar
Yeah I'm trying to keep it stock-ish, I am not really a stock person, my other two rides
Old Mar 30, 2017 | 06:05 AM
axlline's Avatar
Ok, so I received my "new" jdm bumper from Stembridge(thanks again for the extra mile ) Installed it yesterday, only thing left to do some paint touch ups and to fix the rear inner fender liners, they have a gap because of the different shape.
Some before shots for reference
Next to each other
and on
Clay barred it and waxed it
All shiny :P
Old Mar 30, 2017 | 07:04 AM
stembridge's Avatar
I love the way this changes the aesthetic of the back of the car - looks sharp!
es
Old Mar 30, 2017 | 07:12 AM
  #32
SilverEX15's Avatar
Here are some more pics, added som non-skid to the rear bumper to cover up scratches from previous owner :/
Lookin' good! I added three 12v outlets. I ran a wire from the battery to a separate fuse block inside the car. From there, I powered the outlets, GPS, dash cam, etc. I used the switch blanks to the left of the steering wheel to install three lighted rocker switches.
For a nice project lasting several days, get a couple of boxes of Dynamat and put it everywhere you can. It makes the car a lot quieter.
Old Mar 30, 2017 | 07:33 AM
  #33
axlline's Avatar
A nice side by side shot
Old Mar 30, 2017 | 07:37 AM
  #34
axlline's Avatar
es
Me too, plus less bumper to get in the way of putting stuff in and taking it out
Lookin' good!
Thanks, I am contemplating the dynamat still, but I like the idea of it being quieter.
Old Mar 31, 2017 | 06:12 AM
  #35
axlline's Avatar
So yesterday's project, with the JDM RS bumper installed there is a gap that the usdm fender liners don't fill. Time to make covers�� I made them out of 2.5mm plastic that I cut and formed with a heat gun.
Next project will be to use my Honda touch up paint to cover the orange.
Old Apr 1, 2017 | 12:46 AM
  #36
Ericd07's Avatar
Looking good ! You should put an "es" on the rear bumper to remember stembridge by
Old Apr 1, 2017 | 09:12 AM
  #37
stembridge's Avatar
LOL! Love the filler plates - super mod to the bumper mod!
es
Old Apr 1, 2017 | 09:52 AM
  #38
SilverEX15's Avatar
I am curious too, This was the first trip after I filled up and reset the trip meter. I know way too soon to be overjoyed and preaching, lol. I know it will go down, but it's the highest I've ever seen on my Fit.
Lots of things influence MPG. When I drive into town, about 20 miles, I'll average 52 mpg, but coming home, it's more like 47. That's what happens when you drive in hilly country. The second thing that influences mileage is temperature - both the car and the air. As the weather gets warmer, I'm seeing average MPG around 44, where I used to struggle to get 40 in the winter. Speed is another major factor. If I take a 65 MPH trip, my mileage will be around 40. If I take the back roads, it will be in the upper 40s.
Any way you look at it, the Fit is a very economical car to drive. My only regret is the absence of a Honda Service Manual. The dealer's service is not very good.
Old Apr 8, 2017 | 10:40 PM
  #39
ab30494's Avatar
the highest i got was 48 mpg so far, yesterday. with eco mode on
a month ago i got 47 mpg with eco mode off.
Old Apr 10, 2017 | 06:38 AM
  #40
axlline's Avatar
Two weeks ago I got 49.8mpg.
