3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
2018 HFP Shocks?
Old Sep 14, 2017 | 05:37 PM
fit419's Avatar
2018 HFP Shocks?
According to this article the new HFP Fit has much more aggressive springs and shocks over the stock ones:
https://www.autoblog.com/2017/08/24/...ty-technology/
I've really been hoping to find an OEM-type shock that would pair well with my Swift Springs on my '15 Fit (it gets a little bouncy in the rear), and I wonder if this might be the answer.
Old Sep 14, 2017 | 05:42 PM
Rob H's Avatar
It probably gets bouncy because they're blown? Stock suspension on lowering springs usually = eventual blown shocks/struts. The stock suspensions is not going through its intended range of motion once lowered.
Old Sep 16, 2017 | 07:32 PM
yah shouldn't be bouncy.. check for leaks. as robh noted, might be blown.
doesn't koni/kyb offer anything for the GK? might want to look into those too.
Old Sep 16, 2017 | 08:07 PM
hasdrubal's Avatar
There's a few threads here already about people using 2nd gen Koni orange with good results, mine are sitting in the garage waiting for enough time to install them.
Old Nov 13, 2017 | 01:08 AM
skatana's Avatar
College Hills Honda has the HFP parts available now.
2018 Genuine Honda Fit Factory Performance Accessories: College Hills Honda
Old Nov 26, 2017 | 08:33 AM
ThadCastle's Avatar
They are available already, shocks and springs look to be about $650.
I would like to know if it's possible to purchase the shocks without the springs (would prefer to run Swift springs for a little more drop. 10mm vs 25mm) from the dealership. Forgot to ask when I was there earlier this week =/
Old Dec 9, 2017 | 07:37 PM
mateusiv's Avatar
This may be a bit of a noob question but would these parts work with the 2015 Fit EX 6MT? At the College Hills Honda website they’re listed as 2018. They have the 2015-2017 as a separate category. Wheels and suspension kit look very appealing. This is probably for a different thread but also considering the progress rear sway bar.
Old Apr 11, 2018 | 11:40 PM
Jetydosa's Avatar
Anyone have these installed yet? I bought a set - they are in transit.
Also curious if there are install instructions anywhere? On CHH site they strangely don't have them like most other Honda accessories.
Old Apr 14, 2018 | 07:47 PM
fujisawa's Avatar
I dig the floor mats.
Old Apr 14, 2018 | 08:13 PM
hasdrubal's Avatar
If you're looking for a how to guide, I used this one from the GE section. Worked great, but I found I didn't need to remove the main part of the plastic trim below the windshield. As suggested on the second page of the thread, using a ratchet wrench gives you enough space to work with just the small panels removed.
https://www.fitfreak.net/forums/2nd-...r-ge8-fit.html
Old Apr 30, 2018 | 04:04 PM
evilchargerfan's Avatar
ratchet wrench ftw .... saved me the trouble of having to remove the wipers/cowl
also.... fun fact (but I dont endorse doing it) .... it is possible to remove the spring minus the spring compressor.
Old Apr 30, 2018 | 06:33 PM
Action Jackson's Avatar
I'd like to get the HFP springs only.
Old May 5, 2018 | 12:34 AM
Jetydosa's Avatar
I don't believe you can get the springs w/o the shocks.
Also - anyone know why the 6MT HFP kit is different part# than the CVT HFP kit? I ordered the AT kit w/o realizing there were different part#s. Trying to figure out if it will work or do I need to send it back to the dealer and pay a restocking fee.
Old May 29, 2018 | 01:48 PM
vinylengraver's Avatar
I'm curious about this as well, specifically 2016 MY compatibility.
Kris
Old May 29, 2018 | 02:57 PM
Shock Absorber Unit, R Front
Part Number: 51611-T5R-A04
2016:
I'll leave it up to you, to research PN's for 2017, 2018:
https://www.hondapartsguys.com/searc..._id=&page_url=
Old May 29, 2018 | 03:22 PM
Thank you for that link. Much appreciated
Kris
Old Sep 5, 2018 | 11:46 PM
LesPaulPlayer's Avatar
My guess is to accommodate the differences in weight between the MT and CVT. The heavier transmission will require stiffer springs up front with properly valved dampers for those stiffer springs. The goal is to have the same ride and handling with either version.
Old Sep 29, 2018 | 09:06 AM
stephenmarklay's Avatar
I am interested in getting this suspension setup. Where should I look for the best prices?
Stephen Lawson
Feb 8, 2020 11:41 PM
blk04sr
Jan 9, 2015 05:36 PM
Tralfamadorian
Oct 3, 2013 08:13 AM
andrewwdang
Aug 14, 2009 02:04 AM
brokenfit
Jun 7, 2007 03:33 AM
