tires for rain
Old May 19, 2020 | 05:41 PM
Megan Heriford's Avatar
tires for rain
I have a 2015 Fit Sport. Currently running Kuhmo Ecsta tires. There is an alarming slippage in even light rain. The tires are better than what was on it before, but I am looking for suggestions. I don't know if the traction control has something to do with the way the car reacts in the rain, the car slips sideways, then immediately corrects., or if it is a tire issue. Any thoughts?
Old May 19, 2020 | 08:32 PM
2Rismo2's Avatar
what's the tread depth on the tires?
I'm running general Altimax rt43 and have been happy with them but they've got about 50k on them. Last time I measured it was between 3-4/32 though so close to needing replacement and you can tell in the harder rains. Wasn't a problem when new.
Old May 19, 2020 | 10:53 PM
marmaladedad's Avatar
Does the slippage occur during quick, side-to-side motions? Or during tight turns (90 degrees)? Over painted lines?
I do not know what your tread depth is, or which specific Kumho Ecsta tires you use, but I have the Ecsta PA51 and they have been good in the rain. I do not push too hard with slick roads, but never have I felt the car slip.
Old May 19, 2020 | 10:57 PM
GolNat's Avatar
Are these newly installed or they have been on the car a while? Tire pressure okay?
Old May 20, 2020 | 09:05 AM
Not sure of current tread depth, but has done this since they were installed new.
Old May 20, 2020 | 09:10 AM
Slippage is on straight roads, with less than an inch of water standing. The ecsta tire I am running is the PA 31 in 185x55x16.. I chose them because they appeared to have a nice edge pattern to channel water from beneath the tire. I wonder if it is the traction control taking over when it feels a side slip? I drive conservatively, particularly in the rain. What I experience is a quick side slip that instantly corrects itself. It is a bit unnerving, as I don't know how it would react at a higher rate of speed, or in deeper rain puddles.
Old May 20, 2020 | 09:12 AM
They have done this since newly installed. Pressure is at vehicle's manufacturer's spec.
Old May 20, 2020 | 10:04 AM
2Rismo2's Avatar
How is the alignment and when last was it done? If you can invest in a tread depth meter (only a few dollars) it can show you how the tread is doing. If certain sections are wearing faster than others, it may show a bad alignment or not rotating tires enough, but you say it's happened since new.
It kind of sounds like a temporary hydroplaning. What speeds is this happening on?
Old May 20, 2020 | 01:41 PM
Odie's Avatar
General Altimax RT43 ( H-rated ) , newly designed Uniroyal Tiger Paw Touring A/S ( H-rated ) ( https://www.uniroyaltires.com/homepa...ar-and-minivan ) or Yokohama Avid Ascend GT ( $50 rebate ) . Leaning towards the NEW Tiger Paw Touring A/S for the FIT , 175/65-15 (H) , Manufacture # 57883 . Have been using the RT43 for 4 years with no issues . Go here for details of the Tiger Paw Touring A/S with pics of tread , https://www.bobistheoilguy.com/forum...-s#Post5380448 .
Old May 20, 2020 | 02:42 PM
Overdue for alignment, but don't want to do it until tires are replaced. Tread is great on front, and within spec on rear (Have tread gauge) It does feel like a temporary hydroplane, but at speeds of 35 to 45 mph, that's a bit strange. I may need to let the Honda dealer take a look. This car was bought second hand about 3 years ago.
ernie88
Aug 20, 2019 12:14 PM
Colonel Panik
Jul 1, 2019 02:14 PM
Gina*Baby
Nov 6, 2016 08:27 PM
Jack92029
Apr 19, 2014 03:45 AM
kr
Oct 13, 2005 11:31 PM
