14" snow do NOT fit...
Old Dec 2, 2014 | 09:46 AM
Ex-MA Hole's Avatar
I had made a few posts and need to reneg them. I was running 14" snows on my 2010 and was going to put them on my 2015. Went this morning. The bolt pattern is the same, but everything else on the 15 is bigger and my snow do not fit. They go on, but just barely.
I now need new snows.
Drat.
Old Dec 2, 2014 | 11:19 AM
Wanderer.'s Avatar
What about it is not fitting? Does the wheel face hit the brake caliper or something?
Old Dec 2, 2014 | 02:35 PM
Padawan's Avatar
I think your post is a bit misleading without additional information about your specific setup.
I can confirm with certainty that the 14" steel wheels sold by Tire Rack for our application fit perfectly. My 2015 EX-L currently has Tire Rack's 14" steel wheels and 185/70-14 Altimax Artics on it with no issues whatsoever.
Old Dec 2, 2014 | 03:32 PM
Ex-MA Hole's Avatar
Ok....fair enough....my 14" steel wheels purchased from Tire Warehouse do not fit. The bolt pattern is the same, but the wheel itself does not leave enough room (maybe 1mm or so) between the calipers on my EX. The chap at the Tire place told me he was not comfortable mounting them as they were too close. I called the dealership and they told me no way, that the whole setup on a 2015 is significantly bigger than a GE. I called a second tire shop and they told me probably not. I called a third dealer/ tire shop and they told me no.
These are the same wheels and tires that were run on my 2010 with no issue.
Old Dec 2, 2014 | 04:40 PM
Padawan's Avatar
Before investing in a new set, I'd suggest torquing them on and measuring the exact clearance. They don't require as much clearance as you might think (generally 2+ mm) so there's a good chance you're fine, regardless of what the "pros" told you thus far.
Old Dec 2, 2014 | 08:07 PM
Ex-MA Hole's Avatar
Sounds fair....I may give it a whirl....
Old Dec 31, 2014 | 11:30 AM
Apexracing's Avatar
I have 15" steel wheels from discount tire that came with my snow tire package. The ex/ex-l come with 16" wheels. So i'm not sure why you would want to go all the way down to a 14". That would be way too much sidewall flex for me.
Old Dec 31, 2014 | 06:14 PM
Padawan's Avatar
I chose the 14" sizing due to the lower cost and the increased protection the taller sidewalls offer from wheel damage due to potholes. "Crisp" handling is not normally among my selection criteria for winter setups.
Old Jan 7, 2015 | 06:19 PM
CreepyD's Avatar
Interesting! Tirerack has 14" as one of recommended sizes. I wonder if my old corolla 14" winter wheels could be used on Fit. That would be significant savings
Old Jan 7, 2015 | 07:34 PM
Wanderer.'s Avatar
They won't fit without a spacer because the hub bore is too small on Toyota OEM wheels.
Old Jan 7, 2015 | 10:14 PM
CreepyD's Avatar
Thanks!
Actually, I am using 14" 'multi-fit' rims on corolla for winter, they just might fit a Fit
Old Jan 8, 2015 | 12:36 PM
Wanderer.'s Avatar
Oh, yes, if they're aftermarket steel wheels the hub bore is generally much larger than it will ever need to be from my past experiences. If it's a FWD Corolla then yes the lug pattern should be 4x100 and they may fit.
SilverEX15
100
Mar 2, 2020 05:26 PM
shawnshank
Nov 17, 2015 06:49 PM
cthall8143
Oct 11, 2012 02:44 PM
d_2
Nov 19, 2011 06:51 PM
Dave10fit
13
Dec 10, 2010 11:04 AM
