Aftermarket wheels!
Old Jan 7, 2015 | 03:28 AM
mtsui's Avatar
Aftermarket wheels!
Hey guys,
I'm planning to get some wheels for my Fit, but I'm still having a hard time to find out what offset for this car, so if any of you guys have aftermarket wheels, please post them(with spec), so I and other people who is interested will have an idea.
thanks
Nick
Old Jan 7, 2015 | 08:57 AM
robertsmithfromthecure's Avatar
The OEM wheels are 16x6 4x100bolts 56.1 hub bore +53 offset
OEM tires are 185/55R16
I got this information from others (fitfreak member Stembridge )posting in the Fit Shoes forum and the 3rd gen sub forum
Here a link for your perusal: -click-
Old Jan 7, 2015 | 09:39 AM
stembridge's Avatar
Here's the direct link: 2015 Honda Fit OEM Wheel & Tire Specs
es
Old Jan 7, 2015 | 09:58 AM
Just get the car at a ride height you like, then measure the distance from the tire to the fender, decide how much more aggressive you want to go and do some math.
That's the best way to determine what wheel sizing to get.
Old Jan 7, 2015 | 05:32 PM
Chazman's Avatar
Don't go too big.
Other than obvious things like clearance & rubbing issue, added weight will hurt the acceletion and MPG.
Old Jan 8, 2015 | 01:14 AM
mtsui's Avatar
oh haha, thanks! I didn't even know there is a thread for it, sorry guys!
Old Mar 2, 2015 | 04:25 PM
mahout's Avatar
Originally Posted by mtsui
Hey guys,
thanks
Nick
stick with 45 mm offset minimum and 6 to 7 inch rim width regardless of wheel diameter. going more than 205 section tires just doesn't help unless looks are your concern.in truth from any distance the width doesn't show up much anyway. do match the rim width to rim range recommended by tire manufacturer using tire rack specs. the lower the profile the wider the rim needed in general. example at 40 profile the 7 inch is likely needed but at 55 6 inch does fine.
good luck.
_nifty_
Mar 15, 2019 11:27 PM
shinjari
Jul 12, 2017 10:17 AM
Francheeze
13
Aug 22, 2014 09:57 PM
hayden
Nov 12, 2012 08:41 AM
Theos92vr4
Mar 16, 2012 06:25 PM
