3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Anyone use the Koni Orange STR 8750 1102L&R
Old Apr 24, 2019 | 09:48 PM
Rob H's Avatar
Looking for feedback from anyone who used the Koni STR orange with stock springs on their GK? Are the 8750 1102R, 8750 1102L and 8050-1131 a direct bolt on or are modifications necessary?
Old Apr 25, 2019 | 07:13 AM
2Rismo2's Avatar
I remember JHN was one of the early adopters to them but he changed out the springs as well: https://www.fitfreak.net/forums/3rd-...-my-15-ex.html
Too bad the pictures no longer work, and he's moved on from the Fit. I don't recall he had to make any major modifications for them to fit.
Old Apr 25, 2019 | 04:42 PM
freak4afit's Avatar
I am running the 8750 1102L with Swift springs on my 2018 Sport. No issues and bolted up fine.
Old Apr 26, 2019 | 01:50 AM
CeeCab705's Avatar
Should work based on this thread...
https://www.fitfreak.net/forums/3rd-...g-springs.html
Old Apr 26, 2019 | 09:59 AM
Rob H's Avatar
Thanks for the link. Everyone seems to be using lowering springs. Not sure if they will work with the OEM stock height?
Old Apr 26, 2019 | 03:47 PM
Alfa38's Avatar
The rear upper shock mounts sit several inches higher than they do in the GE8, which is accomdated for with the OE shocks by having a longer rod (the shock body is almost identical in length comparing GE to GK). The effective working length between the two is essentially the same. A shorter spring would likely be best, as the shorter rod length of the GE-spec shock reduces the axle droop, but there is only about a half inch difference between the GK and GE OE rear springs. I measured all of this when we swapped GK OE struts/shocks/springs into our GE8, and wrote a short thread about it. That being said, the best solution is to use springs that have a rate that is paired with the Koni damping/rebound characteristics compared to stock.
Old Apr 26, 2019 | 11:20 PM
evilchargerfan's Avatar
it would work
of course.... lowering springs would make the setup come alive
by wild coincidence.... i have a set for sale, paired up with swift springs (mild drop, high quality, you know the drill) .... pm if interested.... willing to ship
accordguyintake
Mar 11, 2020 01:45 PM
utsug
Jun 19, 2019 04:58 AM
jrv784
15
Nov 4, 2018 11:53 AM
pearl
Aug 2, 2016 12:11 AM
Fast1one
Mar 31, 2015 03:47 AM
