08 fit A/C problems
Old Apr 29, 2019 | 07:59 PM
Loganlecain91's Avatar
08 fit A/C problems
Hello my 2008 Honda Fits ac recently went out I’m looking for any advice or tips to help me find the cause of what the problem is, here’s what I know so far , when the ac stopped working at first I’d be driving with the ac on and I could clearly hear the compressor thump loud like it was slipping out of gear, it would go back and forth between on and off but turning off with a loud thud each time, I recently took the clutch off the compressor and tried to do the shim(washer) removal trick I keep seeing on the internet...nothing happened, I have replaced both the compressor clutch relay as well as the condenser fan relay, nothing changed, the condenser fan also will not turn on, at least I believe it is the condenser fan, when facing the front of the car the right fan does come on when I turn the a/c on and off when I turn it off, the left side fan which is the same side the compressor is on does not engage. Also my low pressure port is reading very high but I read that is normal since the system is not running... I have checked all of the possible fuses in both boxes, also my dome light randomly stopped working completely my doors will on lock all the doors of the car is running if not you have to manually lock each one individually and the bell that rings when the headlights are left on when the car is shut off doesn’t sound anymore, I have removed a broken radio from the car and I believe that’s when the light bell and door locks went out.. please help me with any information you might have to help me solve this issue thanks
Old Apr 30, 2019 | 12:11 PM
doctor J's Avatar
Most likely the condenser fan motor is dead
1) Unplug the condenser (passenger side fan) from wire harness.
2) use freshly charged 9 volt Duracell or Energizer battery and apply power to the fan directly; working fan should start to spin slowly
Old May 2, 2019 | 11:21 PM
Update
I jumped the fan and nothing happened, I replaced it today and the compressor still will not engage... when I removed the clutch last week it looked pretty worn down... is it safe to assume that the clutch is the remaining issue?
scarvalho
Oct 26, 2020 11:50 AM
kakrohn
Aug 31, 2020 04:13 PM
KippoSleek
Jul 21, 2019 10:50 AM
Faoladh
Aug 17, 2017 10:06 AM
urbie4
Dec 3, 2016 02:16 PM
