Glove Box light
Old Nov 28, 2006 | 01:35 AM
Fit of RAGE's Avatar
Glove Box light
Hey, here's a pic of my glove box light. The first pic is of the dual cold cathode provided by www.oznium.com (no i dont' work for them) the second pic is of the light at night with no flash
Old Nov 28, 2006 | 01:46 AM
gettinafit's Avatar
What circuit did you hook up the light to? Or is there wiring already there!
Old Nov 28, 2006 | 01:47 AM
I stole power from an empty fuse. (#24) in my Sport AT, it is not used. I ONLY TAPPED INTO THE POWER SIDE FO THE FUSE!!!!
Old Nov 28, 2006 | 02:06 AM
gettinafit's Avatar
this glove box light has a switch that works with the open/close of the box door?
Old Nov 28, 2006 | 08:52 AM
nope, it gets power when the ignition is on.
Old Nov 28, 2006 | 09:06 AM
sillypuddy's Avatar
Someone that Posts too much
so it's on all the time?
-joe
Old Nov 28, 2006 | 09:27 AM
TeamEMC's Avatar
Thumbs up
Cool Idea, You could use a mercury switch and then it would turn off when you close the door. Might try that today Since I'll be working on the Fit.
Old Nov 28, 2006 | 11:33 AM
-joe
It's ONLY on when the key is in the Accessory or ON position.
Old Nov 28, 2006 | 12:40 PM
JDMish's Avatar
so your saying it's on all the time? thats pretty much all the time
+1 for a great idea though. the light is really needed for the box. can you see it while the box is closed?
Old Nov 28, 2006 | 12:44 PM
It's on when the car is on. When the key is out of the ignition, the light is not on.
Old Nov 28, 2006 | 06:34 PM
revs to 9's Avatar
Honda Fit Forums Moderator
Good idea Toy Yoda. I would be interested in this if it could be turned on and off at will. If anyone does this, please do a write-up. Thanks.
Old Nov 28, 2006 | 06:47 PM
JDMish's Avatar
you could probably just put in a switch in line and have control anytime you need.
Old Nov 28, 2006 | 07:38 PM
sy11580's Avatar
I think we can add a switch on it to turn it on and off, right? Good idea to do that!! So do you add extra wire to get teh power??
Old Nov 28, 2006 | 07:46 PM
gettinafit's Avatar
We can figure that out SY!
Old Nov 28, 2006 | 08:03 PM
sy11580's Avatar
yes, do you want to do that??? I think is is good to have a light in the glove box, but always on that may have problem. So, that why I want to add a switch on it!!! Seem like we are going to do another DIY!!!
Old Nov 28, 2006 | 09:52 PM
j5ive's Avatar
Great idea Toda!
The first time I had to get something out of the glove at night, I absolutely hated the fact that it didn't have a light in there. I think I actually have a spare CCFL somewhere at home. Maybe I should go and hook it up like you did.
As for a switch, I can't imagine it would be very difficult. You can get CCFL for computer cases very easily, and they're already setup to run 12V DC. So just run a wire from a power source, like for instance, Toy Yoda did with a empty fuse slot, then add any automotive grade switch in-line before attatching to the transformer for the CCFL. Hook up the switch somewhere within easy reach inside the glove box, and it's done!
For a cleaner setup, buy a computer power connector so you can easily connect/disconnect the CCFL in the future. Or just cut off an unused one from your computer's power supply. Most CCFL tubes for computer cases already come the other side of the connector for plug-and-play install.
If someone really wanted to, I'm sure they can go to electronic stores, or heck, even a junk yard, and pull out ANY glove box pressure switch so that the light will only be on when the glovebox is open.
But wow, CCFL in the glovebox! That would be/IS super bright! I love it Toy Yoda!
Old Nov 29, 2006 | 11:30 AM
gettinafit's Avatar
Call me, we'll go to radio shack, and pic up parts!
Old Nov 29, 2006 | 03:15 PM
eNAyeM's Avatar
someone needs to do a write up for the less technically inclined!! good work, that looks awesome, and something that is REALLY useful!
Old Nov 30, 2006 | 09:00 PM
i wanted to put a switch in, but i just didnt' feel like drilling a hole in my brand new nice dashboard. or in the little cover piece where the JDM coin tray is. I'm SUPER LAZY!!!
Old Nov 30, 2006 | 11:38 PM
sy11580's Avatar
I have a idea that you don't really have to drill a hole on the dashboard!!!
I'm thinking adding a switch in the glove box. I don't know how to explain what kind of switch that I want to use...........that's look like some of the car with the light on the door (When the door open the lights on/when the door close the lights off). It looks like a spring switch, the spring down the light off, then the sprin release the light will on.
