GK5 Comfortable Lowering Springs (Static vs progressive)
Old Aug 7, 2019 | 11:19 PM
LulzKev's Avatar
Hello all!
Hoping to spark some discussion and get some input on lowering springs for the GK5. More specifically, the difference in comfortability between progressive rate and static rate springs. I'm using this car as a daily which will see upwards of 3-4k miles a month. Comfort is the main goal, but would like to get this thing more stable on the highways.
I'm looking at Eibach and Swift springs specifically. Eibach has a lower rate on the bottom end but a much heavier weight on the top end also lower the car a bit more compared to Swift's. The Swift springs are just a bit stiffer then stock and provide a modest drop.
I feel like the Swift springs won't feel much different than stock as far as ride comfort goes so I feel like they are definitely a safe bet. However I'm curious about the eibachs. They're significantly softer than OEM rates without any load on them so I'm wondering if that will translate into a much more comfortable ride (excluding extreme bumps that is) while still providing much more stabilization under load.
What are your thoughts on static vs progressive rates?
OEM:
F - 131 lbs/inch rate
R - 148 lbs/inch rate
Eibachs:
F - 120 - 160 lbs/inch rate
F - 1.2" drop
R - 86 - 183 lbs/inch rate
R - 1.4" drop
Swift:
F - 140 lbs/inch rate
F - 1" drop
R - 157 lbs/inch rate
R - 0.9" drop
Old Aug 8, 2019 | 10:12 AM
evilchargerfan's Avatar
https://blog.modbargains.com/linear-...best-4-street/
I googled the topic as this all sounds interest, and spent some time reading a few articles and watched a few youtube vids. if the above link holds true, progressive rates should offer you the most comfort. those eibach's may be the way to go
Old Aug 10, 2019 | 01:23 PM
Action Jackson's Avatar
I've had several different springs on my Protege5 when I used it for DD and track days. I prefer the Linear rate springs over the progressive rate personally. Everyone's mileage will vary.
mikeDF
3rd Generation GK Specific Suspension & Brakes Sub-Forum
35
May 27, 2015 07:38 AM
rays
Mar 26, 2012 07:33 PM
Zivman
May 2, 2011 11:37 PM
danger69
22
Feb 13, 2011 01:28 AM
runbikerun
Apr 20, 2009 02:30 PM
