Moisture on your windhield and side windows???
Old Dec 1, 2006 | 12:17 AM
Fit-in-Richmond's Avatar
Question Moisture on your windhield and side windows???
I know this question is being discussed in other forums. I seemed to be getting a lot of moisture on the windows of the Fit. Am I the only one having this problem??? I try to drive with defrost on at all time but the side windows always get fogged up real quickly... and I'm usually the only one in the car... is this a problem with plastic siding of the windows???
Old Dec 1, 2006 | 09:03 AM
Fit of RAGE's Avatar
are you on re-circulation?
Old Dec 2, 2006 | 05:49 AM
jvf1mikey's Avatar
That's what I was gonna say.
Old Dec 4, 2006 | 06:00 PM
j5ive's Avatar
Probably moisture trapped in your cabin during the heavy rain we had in the beginning of November. Everytime you get in your car from outside with your wet clothes/shoes/umbrellas/etc, the water on those gets into the car's cabin and often trapped. Run your HVAC getting fresh air, and crack the windows so drier air can get in and wet air can get out. Adding the A/C on also helps dry the air. And speaking of A/C, make sure the condenser drain tube is not plugged by debris or snow/ice.
On my in-law's previous Van, we actually had to run a home dehumidifier one time becaes a bucket of water (carrying flowers) actually spilled inside. I don't think yours is quite that bad.
Old Dec 4, 2006 | 06:45 PM
wk406's Avatar
Try pointing the two upper side vents to the windows while in defrost mode. I noticed that is air coming out from those vents.
Old Dec 6, 2006 | 05:37 PM
shipwrek's Avatar
These are all good points. The problem is also further complicated when your windows are not clean. Moisture in the air needs something to 'catch' onto in order to fog your windows. This is the same effect created by imperfections and things in a glass full of soda where the bubbles seem to stem from a certain location. Just get those windows clean and not only will your fogging decrease but your de-fog time will get considerably shorter.
Old Jan 12, 2007 | 03:37 AM
Spinkman's Avatar
YES!!!!!! Keep your windows clean and FOR GODS SAKE! don't wipe it with your hand so you can see!!!!! hugest pet peeve!!! never touch my windows on the inside!!! (ok so I'm a little ****...)
LLLC1393
Jan 25, 2017 10:12 AM
zukered
Oct 25, 2010 11:36 AM
jsnatchdiggity
Jul 28, 2010 05:26 PM
charlottefit
Sep 11, 2007 07:53 AM
igeek
Feb 13, 2007 12:18 AM
