Sponsored by:
Sponsored by: CARiD
Solid shifter bushing.
Old Nov 9, 2020 | 01:28 PM
RD36's Avatar
Are the shifter bushing rubber? I am not talking about the inside the engine bay bushing.I already changed those with Acuity bushing. But it seems it didn't do much to the feel of the shift. Anyone try to use washers to replace the shifter bushing under the console?
Old Nov 9, 2020 | 05:47 PM
elkaku's Avatar
You gonna have to go with a modified CRZ short shifter or a WK one, since up to date, those are the ones that are available.....
Old Nov 9, 2020 | 07:58 PM
RD36's Avatar
Thanks for this.
Wk is too damn expensive where can I purchase the CRZ one?
Old Nov 9, 2020 | 08:12 PM
elkaku's Avatar
Axionind.com used to sell them, already modded .... that's where i bought mine... i believe BuddyClub sells them too, since its their product...
https://www.fitfreak.net/forums/3rd-...shift-gk5.html
Check out this thread... ☝🏽☝🏽☝🏽☝🏽☝🏽
Old Jan 15, 2021 | 04:35 AM
RD36's Avatar
I got these shifter bushing. On the package it says fit GK5 solid shifter bushing. But I don't see you ladies trying these on ur gk5's.
Old Jan 15, 2021 | 07:38 AM
elkaku's Avatar
Was thinking on getting them, since I have the shifter cable ones and the BuddyClub short shifter..... And had to reuse the oem ones and they were a bit TIGHT!!!!...
Old Jan 15, 2021 | 05:46 PM
RD36's Avatar
You went the expensive route. I am barato!! It's in!
Old Jan 15, 2021 | 08:51 PM
RD36's Avatar
I like them. They do improve your shifting. I used to have problem with a hesitant 3rd gear that seems to have improved. Overall it's good for the money. Onto the next upgrade.
Bang for buck which would you chose?
Rigid Collar.
Frnt Swaybar.
Or springs?
Old Jan 16, 2021 | 10:10 AM
elkaku's Avatar
LoL!!!! Well if you compare it to the WK it was "cheap" !! I've got them {the solid shifter bushings} on the cart.... Might buy them!!! Thnx for the insight!!!
BTW are you planning on upgrading intake parts.... I can fabricate a TB spacer to use bigger than stock one.... DM me for info!
Go to my IG... @kaku_gk5
Old Jan 16, 2021 | 11:03 AM
RD36's Avatar
IF you decide to get them. The install advice from me is to put rags between the carpet on the side. To prevent it falling in there.Stops you having to take the seat off and lift the carpet to get the darn thing lol.
Interesting about the TB spacer. Any threads on this so I can research it..
Old Jan 16, 2021 | 11:30 AM
elkaku's Avatar
There's no thread here that I could find... And on the web i only found one to use between the OEM TB but not to use any other.... Larger TB's... That's when I decided, with a friend of mine to go ahead and make one for my GK...
I used an S2K TB {67mm} at first, BUT it was WAY TO BIG for a stock internals fit engine... So we decided to downsize it to a CiViC or TSX, or Odyssey one which all are 61mm, {they are a bit different physically, but same diameter and use the same gasket...}
So if interested.... These are the one I KNOW {since we measured them all} work without any problems on the stock engine.... With aftermarket intakes or modified OEM one....
Go to my instagram.... I have pics of all my kids there... @kaku_gk5
Old Jan 16, 2021 | 07:28 PM
RD36's Avatar
I would love for more power. But right now the focus is handling..
I want this car to ride straighter flatter and comfortable. I feel it's too bouncy on rougher roads.
There's a guy on FB that used gen9 civic coils on the fit with good result. I can't afford brand new coils so this might be an option.
ostronomer
Jul 10, 2014 01:51 PM
CrystalFiveMT
Mar 6, 2010 10:07 AM
No_Skillz
Feb 17, 2009 01:09 PM
xanatos
Aug 26, 2008 11:06 AM
sethne
Jul 10, 2008 09:58 AM
