Jack Hardware Storage
Old Feb 11, 2024 | 03:29 PM
dmendez0106's Avatar
Does anyone have any pictures or videos to share on the proper way to store the Jack hardware in the spare wheel well...The noise it's making back there is driving me nuts....any info or tips on this will be greatly appreciated.
Old Feb 11, 2024 | 04:18 PM
Virulence's Avatar
I think the proper thing to do is remove the jack and spare tire entirely.
If you've ever tried to remove the lug nuts with the provided wrench, it's not really possible. You would need a cheater bar or an actual breaker bar.
This is why I opted to remove mine and replace it with a piece of plywood under the carpet for my cargo.
Here's a picture for you. You might also try checking your owners manual there should be some pictures. Everything has a cut out in the foam more or less.
Old Feb 11, 2024 | 04:58 PM
This is very helpful, thank you Virulence.....after seeing this pic I think my issue is I don't have or the Fit didn't come with the black styrofoam organizer that is in your pic. What is the actual name of that part and perhaps all I need to do is order that to organize the jack hardware?
Old Feb 11, 2024 | 05:00 PM
My Fit is a 2010 Sport..since i didn't purchase it new I don't really know if it that black styrofaom organizer comes standard in the 2010 Fit Sport
Old Feb 11, 2024 | 09:11 PM
SiXiam's Avatar
I can say for certain my 09 doesn't come with styrofoam. The scissor jack goes in front of the tire. It has a little cubby hole, but basically you expand it to wedge it in the spot. The tire iron and screw in tow hook is just in a little bag. Here is where the jack goes:
Old Feb 11, 2024 | 09:41 PM
Thank you..this helpful...thanks again
Old Feb 12, 2024 | 06:25 AM
Frenzal's Avatar
Just wrap the tools in old towels and store in the spare in the trunk. Arrange so it doesn't move around.
Old Feb 12, 2024 | 10:31 AM
Drew21's Avatar
The lug wrench that comes in a Fit can be a bit of a struggle, especially if your lug nuts are over tight, which isn't uncommon if you've visited a commercial tire shop or similar.
If you need to use the lug wrench in the car and are struggling, the easiest approach to take is as follows.
1) Orient the lug wrench on a lug nut so that the bar portion is parallel (or as close as possible) to the ground.
2) Carefully step with one foot onto the bar while steadying your balance on the side of the car. Unless you're a featherweight or your lug nuts are stupid tight your body weight should break the lug nut loose. Once they're loose, they should turn easily, even with the short lug wrench that comes with the car.
My 2010 Fit Sport also doesn't have the styrofoam organizer. As others have mentioned, there is a plate behind (towards the rear bumper) the spare tire. The scissor jack is positioned under this small plate and you then hand-turn the adjustment screw to expand the jack slightly and lock it into place.
SilverEX15
Sep 26, 2017 08:55 PM
trashercan
Sep 24, 2017 05:46 PM
Fitguy07
Jun 25, 2014 04:57 PM
dstahnke
May 3, 2012 10:14 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
