How many transmission pressure sensors are there?
Old May 27, 2024 | 01:08 AM
DeeJ's Avatar
2010 Honda Fit. CEL and blinking "D" indicator. My OBD scanner shows me Error P0847, a bad transmission pressure sensor. That's fine, i can swap that out, but i found an odd thing:
The error clearly states, "Short in 3rd Clutch Transmission Fluid Pressure Switch Circuit". And the parts diagram shows two different sensors, one labeled 3rd Clutch, one labeled 2nd Clutch. They have the same part number.
Diagram here: #10 and #11. https://www.hondapartsnow.com/parts-..._solenoid.html
The parts diagram points to them at different locations. Every tutorial I've watched on Youtube addresses one sensor when dealing with that code, and it's under and to the right of the transmission fluid dipstick on the drivers side.
Are there two sensors? If not, why would the parts diagram list it?
Old Jun 8, 2024 | 07:37 PM
fyt's Avatar
fyt
Yes, there are two transmission pressure sensors. If there is a problem detected with the other one, it should throw a different error code (usually ending in 8).
https://www.fitfreak.net/forums/2nd-...locations.html
Edsar2010
Mar 1, 2020 05:01 PM
cranky18
Jul 12, 2019 01:21 PM
junior40er
Dec 1, 2011 06:35 AM
bayarea5100
Nov 27, 2011 11:16 PM
