Honda fit 2012 hybrid missfiring
Old Nov 17, 2024 | 05:46 PM
noman76's Avatar
hi i have honda fit 2012 hybrid model bought in june 2024 its started to misfired from june after first misfire i change 4 inlet spark plugs its work for 20 days and again misfired after 20 days i do exhaust side 4 spark plugs change than after 20 days its misfiring, it cylinder 3 and spark plugs become black color and molded with oily too. if you change new spark plugs and start the car in 10 minuts spark plug get black color. now i clean spark plugs every weeks and using the car if im not cleaning its misfiring
some mechanic said i need to change all ignition coils. please advice coil part no CM11-119 and CM11-118 Hitachi
Old Nov 18, 2024 | 10:12 AM
bobski's Avatar
Is the engine losing oil? The 2010-2013 Fit Hybrid and 2009-2014 Insight hybrid used the same engine (LDA3). The 2012 Insight had an oil burning problem due to defective piston rings. It would not surprise me if that carried over to the Fit as well.
Old Nov 18, 2024 | 10:17 AM
noman76's Avatar
yes, oil burning every two weeks 400ml
Old Nov 18, 2024 | 10:42 AM
bobski's Avatar
Replacing the piston rings requires disassembling the engine block and honing the cylinders. Honing releases grit that requires a thorough cleaning to remove before reassembly. That means stripping the engine down to the bare block before honing and cleaning. All in all, it's a few wear parts (rod and crank bearings, engine seal kit, timing chain kit, maybe a valve job) shy of a complete engine rebuild. If you're on a budget, a salvage engine from a different year (only the 2012 year was affected AFAIK) would likely be cheaper. If you have the time and skills, doing the rebuild yourself might be cheaper, resulting in a fresh engine.
Old Nov 18, 2024 | 11:13 AM
noman76's Avatar
Do you know anyone doing in uk
Old Nov 18, 2024 | 10:00 PM
bobski's Avatar
I'm in the US, so no.
Ask your dealer if there's been any recalls for the issue. If UK Honda is anything like the US, their pricing will be absurd. Don't let them talk you into a diagnostic fee or anything unless they're likely to cover the costs of the repair.
It's probably worth asking about the 2012 engine on InsightCentral.net.
Last edited by bobski; Nov 18, 2024 at 10:19 PM. Reason: Added link - the UK got the same bum engine
Hombre de senoras
Jun 21, 2023 09:29 AM
cici235
Jul 31, 2021 10:51 AM
wackyflik
Oct 4, 2014 09:11 AM
bellzGD3
Mar 21, 2014 11:32 PM
bryan720
Feb 17, 2007 08:06 PM
