Windows Fogging and Frosting Up
Has anyone else had issues with the windows fogging up and actually frosting over in cold weather?
I am from Minnesota and its been really cold here lately and I can never get my front and rear windows to defrost all the way.. I have to point the heater vents on the front windows just so they wont frost over on the inside..the back windows never come unfrosted at all..
Is there anything i can clean the inside of my windows with?
thanks
thanks
I hope this helps
The best thing you can do for the inside window is to clean it with a window cleaner and squeege wipe it. Mosture will only be on the glass if it has a partical to cling to.. You know dust dirt that kind of stuff.
After you have done that and if it does not satisfy you try to apply anti fog products. I think rain x makes some. I have never tried the rain x.
Another thing that may help and is more economical: I do know that if after you clean the glass as stated above you could get a towel and wet it then rub in some soap such as ivory. Take that rag and wipe the inside of the window with it. Buff it dry with a dry cloth until it looks acceptable. work with that until you perfect it. I think you will understand as you go. I actually have wanted to try this for my rear view mirror....
I really think that the squeege clean glass may do the job. good luck
If you leave the windows slightly cracked open especially when the car is sitting in the sun, it will eventually go away. I am in the Upper Peninsula and had the same issues. Being that the snow comes inside off my shoes and I only drive a few miles at a time, the frost accumulated quickly.
I recommend just leaving the windows cracked and eventually they will defrost. Just because it is cold outside doesn't mean evaporation will stop (it just goes really slow). Keeping the windows clean will allow the frost to form in a uniform film opposed to spots or lines where you tired to scrape it off. Another reason why you can tell your friends or kids to not touch the windows.
Good Luck,
~Tony
Good Luck,
~Tony
hence, why the a/c comes on with the defrost
Fit-in-Richmond
Jan 12, 2007 03:37 AM
