Foglight removal HELP ASAP!!!
Old Mar 12, 2007 | 07:18 PM
Luichenwai's Avatar
I need some help guys.. i am in the middle of installing HIDs on my car.. i have all the screws/clips off the front bumper but im not sure how to disconnect the foglight bulb..... I already removed the 10mm bolt from the front.. its the actual fog light bulb i cant disconnect... Help!!
Old Mar 12, 2007 | 07:52 PM
Fit of RAGE's Avatar
in the front of the bumper, there's the housing for the foglights. if you look towards the inside of the foglight from the center of the car, there's a 10mm/phillips bolt holding the foglight housing in place. take that out and then just unhook the foglight form there.
Old Mar 12, 2007 | 07:55 PM
Luichenwai's Avatar
its the unhooking of the foglights I can't get.... It wont come out.. Im pressing the tab and the pulling but it wont come out...
Old Mar 12, 2007 | 07:58 PM
koolkevin1107's Avatar
omg i know its HARD!! u gotta push the tab hard. Another way 2 do it is to twist off the bulb FIRST and then disconnect the bulb from the harness. Mine was really hard 2 do but once u get it off the first time, it'll b a sinch the next time.
Old Mar 12, 2007 | 08:02 PM
Luichenwai's Avatar
How do I twist the bulb off? Which way do I turn? If im looking at the front of the car.. which way to turn?
Old Mar 12, 2007 | 08:35 PM
fithouston's Avatar
yeah mine was a pain
if you feel towards the back of the bulb in the center there is a tab/button press hard and pull
if not you should twist the bulb left all the way then pull
Old Mar 12, 2007 | 08:52 PM
twist to the left like ur unscrewing a bolt. newayz check out da pm.
Old Mar 13, 2007 | 12:50 AM
Luichenwai's Avatar
Everything is DONE. Thanks all for help! :-)
xLilFantasyx
Nov 9, 2023 07:34 PM
koolkevin1107
338
Jun 3, 2013 10:00 PM
britdevine
Jan 3, 2010 02:44 PM
ericman20
Jul 18, 2008 01:54 AM
trancedsailor
15
Jun 24, 2008 06:29 PM
