removing front pillar trim??
Old Mar 29, 2007 | 10:38 PM
beans2_98's Avatar
I got a universal auto-dimming mirror (with compass & temp gauge) to replace my boring stock mirror but i'm having troubles running the wiring down the front pillar. Has anyone tried removing this piece successfully without breaking any of the clips? I know there's an airbag in there and i have to disconnect the battery. The manual I have suggests using "a handy removal set or equivalent". Thanks.
Old Mar 30, 2007 | 07:50 PM
KenClunk's Avatar
I was able to wire my GPS through the driver side pillar by gently pulling on it from the door jam. I simply pulled the black trim out which leaves a small opening. My wire only went to the small corner window.
I am not sure I would want a wire running all the way through because if the aire bags ever needed to deploy the might get caught on the wire. I did not want to break a inside clip by pulling on the trim. It is secured very tightly and I, like you, could not find a safe way to remove it.
Old Apr 1, 2007 | 11:47 AM
beans2_98's Avatar
well i was able to feed the wire down through the arm and got it to under the dash. Now i just need help locating where the ignition wire is and where the wire is for the backup lights. anyone? thanks.
LarryS
Jun 23, 2016 03:58 PM
GrayGhost
Oct 28, 2015 10:53 AM
Spacecoast
Apr 3, 2010 08:23 AM
vwli
Mar 1, 2009 02:02 AM
ezduzit
Mar 21, 2008 08:16 PM
