Clutch question (can i tighten it up)
Old Apr 28, 2007 | 05:45 AM
s0x's Avatar
s0x
i wasnt so sure where to list this in the forum but im very much used to having a stiffer clutch and i actually like it that way... everytime if test drivin a fit the clutch is SOOOOOOOOO easy to push in wich for some ppl may seem nice but it feels almost flimsy to me... so im wondering is it a clutch that i could if i felt nessesary adjust (not sure hydrolic is adjustable or not) or am i stuck with the featherweight clutch....does anyone know any tricks to maybe stiffin this up?.....
thanks you
Old Apr 28, 2007 | 04:36 PM
Carbuff2's Avatar
Maybe you could put a second return spring on the pedal?
You can increase the force required by installing a smaller - bore clutch master cylinder or increasing the stiffness of the pressure plate (more clamping pressure). But those are more involved, expensive options.
I have various manual-trans cars (5.0 Mustang, Lotus Esprit, CR-V, Fit) and I CAN tell you that you will get used to the lightweight clutch. I thought my Mustang's clutch was a bit heavy and the Lotus' throttle pedal stiff, but I don't even think twice about the differences in pressure now.
Old Apr 16, 2008 | 02:43 PM
Giggles's Avatar
If you think the Fit has a light clutch try driving the Toyota Matrix.
Old Apr 16, 2008 | 02:47 PM
yeamans17's Avatar
I would think the best alternative would be a higher pressure pressure plate, something with a little more umph, but does anyone make one yet?
Bounce
Jul 15, 2017 07:28 PM
Mrksstk
Apr 11, 2014 08:43 PM
Cachupin
Jan 5, 2011 10:24 PM
synmyo
Aug 29, 2010 08:06 AM
Previc93
Sep 8, 2009 11:14 AM
