VS3 Voltage Stabilizer
Old May 21, 2007 | 03:12 PM
TomiGunz's Avatar
Frequent FitFreak Poster
Hey guys,,
Mine came in the mail today. I'm going to install it later on this evening when I get off of work. Too bad the guy doesn't have any type of logo printed on the box. It looks nice. The wires are smaller than I thought. I thought these voltage stabilizers come with thickass wires.
Anyway,, It looks like we hook it up to the battery +/- terminals direct? I read the instructions over and over, but I'm weary about connecting both wires directly to the battery. But I'll wait for more info..
-Tomi
Old May 21, 2007 | 03:54 PM
WhatFreshHell's Avatar
Cool. I hope mine came today as well.. (though I don't think I will have time to put it in until tomorrow, hah).
If you decide to put it on today, take pics as you do. Would be greatly appreciated!
Old May 21, 2007 | 04:40 PM
koolkevin1107's Avatar
yes thats all u gotta do. the terminals do not touch each other. Just make sure u DO NOT hook them up backwards cuz it's gonna burn ur wiring, ecu, etccc. that is how my nrg epac is hooked up.
Old May 21, 2007 | 06:07 PM
TomiGunz's Avatar
red goes to +
black goes to -
I sure hope I don't get it backwards with the color coded wires.. =)
Old May 21, 2007 | 08:08 PM
TomiGunz's Avatar
went under the hood to find a place to mount the VS3. The only place I found was in front of the battery. Well, when you bought the car, they sprayed the engine bay with oil stuff. YOU CAN'T USE DOUBLE SIDED TAPE! Bummer! I'm going to find something to mount it to. Then I'll take pics. Probably won't be today..
Old May 21, 2007 | 08:40 PM
well...i mounted mine (at first) to the front of the battery box before i had my last station powerbox. It was a perfect fit and it stuck perfectly w/ double sided tape. When i got my intake, i had to remove the battery box so now i think ima stick it straight to the battery itself (i havn't done it yet). As for cleaning ur engine bay then using double sided tape, just get some rubbing alcohol or acetone and rub where u want to mount the thing so it doesn't stick to the cleaner. Then u should have a nice dry fingerprint and oil free surface.
Old May 22, 2007 | 12:22 AM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
The place I mounted mine was off the brake fluid reservoir , the double sided tape didn't do the job so I got some zip ties and they work just fine.
Old May 22, 2007 | 12:50 AM
boyetssilverfit's Avatar
Where i can buy this VS3 voltage stabilizer,any website or vendors that sell here at fitfreak.net?
Old May 22, 2007 | 01:17 AM
TomiGunz's Avatar
I wanted to zip tie it near the brake fluid res. But I want it right in front of the battery box so that I know it's there! Kinda wierd to mod something without showing it. =) I'll figure something out..
Old May 22, 2007 | 12:34 PM
sliverworm,could you please tell me where to buy these VS3 voltage stabilizer?
Old May 22, 2007 | 01:22 PM
sLiVeRwOrM's Avatar
I did a group buy starting last year, it just picked up recently and finished it. we still have like.. 2 or 3 left.. PM me they are $50 shipped The first three to PM me will get them.
Old May 22, 2007 | 02:01 PM
ok i just did
Old May 22, 2007 | 02:02 PM
How is it so far?
Please get a pic of yours!
Old May 22, 2007 | 02:45 PM
sLiVeRwOrM's Avatar
if there enough intrest we can get more of them made.. each one is made by hand.. by one guy
Old May 23, 2007 | 03:26 AM
cheffyjay's Avatar
I had posted this question on the T1R thread but no response:
Would this pose any danger to a mechanic unfamiliar with this thing? Could it be accidentally discharged and hurt someone? (Any significant amperage stored in the capacitors?)
Also, if you wanted to 'turn it off' for any reason, (performance testing?)would you simply disconnect the positive side or the negative side?
thanks!
Old May 23, 2007 | 05:55 AM
cheffyjay's Avatar
Mr. Claymore--what is your take on these devices? Why wouldn't the factory just put something like this on the car if it was really helpful? (Or should I start a new thread to discuss the efficacy of voltage stabilizers?) I'd appreciate your opinion.
Old May 23, 2007 | 01:55 PM
TomiGunz's Avatar
That's like askinng why our Fits didn't come with turbo/super chargers out of the factory.
Old May 23, 2007 | 02:13 PM
cheffyjay's Avatar
Oh, I don't know--a few dollars (maybe pennies for a big automobile manufacturer) worth of electronics an very little R&D for a stabilizer is very different from a forced induction system.
Old May 23, 2007 | 06:39 PM
if HONDA can't even put a dead pedal on a FIT ,you think they will put a VOLTAGE STABILIZER?
Old May 23, 2007 | 09:14 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Whats the VS3? I have the T1R Volt Stabilizer and I love it.
I have the Ground wires, Volt Stabilizer, and the Ignition Booster which is actually a stabilizer also.
BIG difference in power when the AC is on. Much more responsive.
