Rattles Under Braking
Old Jul 5, 2007 | 09:25 PM
cycoxtr's Avatar
I've been driving around in an area that full of expansion joints and damaged road. Lately I've been getting a rattling noise if I hit some rough road while braking. It sounds like a metal spring when you pull it back and release it, like a "boing" sound. It only happens sometimes. On other times, under similar braking situations, the brake pedal feels like it's binding up on something. It feels like it catches on something the first few centimeters of travel and then releases. Any idea on what's going on with my car? I'm thinking of having my Honda dealer check it out.
Old Jul 5, 2007 | 09:44 PM
SPON FIT's Avatar
sounds like the abs is kicking in to me
Old Jul 5, 2007 | 10:28 PM
cycoxtr's Avatar
I thought ABS only kicks in under hard braking. Or does it also kick in when it detects wheel slippage due to the rough pavement? I forgot to mention that rattling sound sometimes happens when I go over speed bump. It's wierd.
Old Jul 7, 2007 | 03:15 PM
nttdemented's Avatar
I used to hear the ABS kick in VERY easily with my base 14" steelies. Just like you describe, braking to a stop light with uneven pavement (basically 60% of all stop lights here in Puerto Rico) and I would get the rattling from the ABS system kicking in.
After I installed my 15" aftermarket rims with a wider tire (195/50/15) I barely hear the ABS kick in over uneven pavement anymore.
Old Jul 7, 2007 | 09:24 PM
cycoxtr's Avatar
I'm going to get it checked out anyway. Because I sometimes hear it when not braking and the front end comes down over speed bumps. Also, I'm not sure if your supposed to feel jolts when the ABS is on, because I feel none.
diesehrl
Aug 2, 2016 01:33 PM
diesehrl
Mar 29, 2016 09:41 AM
TiMo
Jun 11, 2008 12:54 PM
HondaFitted2007
Jan 14, 2008 03:24 AM
743power
16
Aug 19, 2007 07:54 PM
