Odd Tire Size Experience?
Old Aug 3, 2007 | 10:19 PM
Sugarphreak's Avatar
Push My Button
Continential ContiSportContact 2 - 195/40R17 (Thread Renamed)
Anybody out there using a 195/40R17 tire?
Better yet, is anybody using this tire size in an attempt to fix an ongoing rubbing issue with a 205/40R17? My big question; Did it work?
I only know of three brands in North America that make and distribute this spec; they are (listed from cheapest to most expensive)
1-Continential (ContiSportContact 2),
2-Hankook (Ventus S1 EVO K107),
3-Pirelli (PZero Nero).
If there are some I have missed availiable in that spec size please post them up, also comments regarding these brands & specific tire model are apprecaited too.
Cheers!
Last edited by Sugarphreak; Aug 20, 2007 at 01:39 AM. Reason: Title Edited to more reflect relevant information
Old Aug 9, 2007 | 01:05 AM
Push My Button
Bump! Nobody running this size?
I am going with a set of 195/40R17 Continential ContiSportContact2's.
Turns out my el-cheapo Lexani 205/40R17's were horribly offspec and pushing the maximum allowable tolerance of physical size. Infact they were larger than a 215/40 in both width and diameter. They came for free with my rims, so I guess I can't complain too much.
Anyway, once I have the new tires installed I will take some pics and review them. My car is running Tanabe GF210's, so I will be testing to see if they have any rubbing at all under heavy loading and cornering. It is my mission to be able to do the "dukes of hazzard" thing with my car and have zero rubbing
Old Aug 17, 2007 | 11:15 PM
Push My Button
Good news!
I am now running the 195/40R17 Continential ContiSportContact2's with the Tanabe GF210 springs; excellent grip and road noise is definetly not as deafening as the Lexani tires although still present (then again, this is a performance tire so that it to be expected anyway).
Did some basic load, bump and corner testing. Happy to report with 850lbs in the car, it has absolutly zero rubbing over bumps, dips or corners. This has completly solved my rubbing problem
I would highly reccomend these tires both as a performance upgrade and to solve pesky 17" rubbing problems!
Old May 1, 2008 | 12:38 AM
Push My Button
Bump (to my own personal thread )
Some good news if you happen to run 17's and need to get rid of the rub bug. A new brand has opened it's doors to the 195/40/17 size.
Currently the list looks like this.....
Welcome a new member to the wonky odd tire Family!!
4- Yokohama S.Drive
The new S.Drive 195/40/ZR17 is the CHEAPEST option for this size of tire. I highly recommend this size to fellow 17"ers who run less than a +45 offset to avoid rubbing!
Old May 1, 2008 | 06:39 PM
lutherb69's Avatar
where are you geting your tires from went looking for some all day and they are saying that all are not being made anymore but the Yokohama at 113.00 each.
Old May 1, 2008 | 08:57 PM
SD_MR_FIT's Avatar
im using right now 205/40/r17 sumitomos htrs in the front
bg goodrich sport in the left back and nito neo gen on the rear
haha THEY CAME WITH THE RIMS!
so with that being said i havnt rubbed at all.
but im going to switch over to federal ss595 for 60 bucks installed each thats a steal!
im tire tucking btw, and thinking about going lower...and have no issues whatso ever with rubbing.
these are mounted on a 17x7.5 45 rim
Old May 1, 2008 | 08:58 PM
SD_MR_FIT's Avatar
man those are skinny tires. i wanna run 215 but im tooo chicken to try it out to see if they are going to rub or not.
Old May 6, 2008 | 04:44 PM
mahout's Avatar
Depending on the offset of your wheels; the rubbing may go away if your offset is more than 36 mm. Probably not if less than 32 mm. 50/50 between 42 and 32 mm.
Old May 23, 2008 | 10:03 PM
Push My Button
Tirerack.com carries 3 of those brands. Also 1010Tires.com (Vancouver based online) carries the other one.
Compare Tire Search Results
Hankook Ventus S1 EVO K107 Tires - Tire Size & Price Details - 1010tires.com
Offset should be considered for sure, lots of people have minor rubbing with the common +42 offset and this is the remedy I would suggest.
It also has a slightly lower profile than a 205/40, the 195/40 is closer to a stock diameter.
Old May 24, 2008 | 01:16 AM
Push My Button
Kind of a neat photo;
195/40R17 shown on the left, 205/40R17 shown on the right.
Old May 24, 2008 | 09:10 AM
mahout's Avatar
Check DiscounttireDirect.com. We get 90% of our ordered tires from them because they ship free and balance and ship sets of wheels/tires free. great boon for our customers.
And they have a wide selection of tires.
jazzwan28
Nov 22, 2014 09:56 AM
Thorzdad
Feb 2, 2014 08:56 AM
joepmac2
Mar 14, 2012 12:19 AM
dcmcelreath
Jun 1, 2008 06:12 PM
Raaaaaaaaaay.
Nov 25, 2006 06:32 PM
