HID turn on
Old Aug 21, 2007 | 09:59 AM
kimo's Avatar
HID turn on
Which alarm that has option to turn on your HID lights.
Old Aug 24, 2007 | 09:55 AM
explosivpotato's Avatar
probably any one that has the option to turn on your regular headlights, because I think the ballasts are wired into the original 12v headlight circuit (someone correct me if i'm wrong). The HIDs also draw less current than the standart halogens, so I think you should be ok with any alarm that has an option to turn on your headlights.
Actually, come to think of it, unless the alarm had a bypass of the factory switch, it couldnt do that unless you had the car set up to turn the lights off with the ignition, and left the switch on.
Maybe someone else with a little bit more information can chime in here as to how this would be done? Hope I helped a little.
Old Aug 24, 2007 | 01:17 PM
03DSM-RSX's Avatar
Frequent FitFreak Poster
you should not turn the HIDs on while car is off. Let alone turn them on/off. This creates a huge drain on your battery and will kill it prematurely. Although HIDs run on lower wattage, they take an incredible amount of power to ignite the ballast/bulbs.
You dont want to run the risk of needing a jump.
Old Aug 24, 2007 | 03:55 PM
kimo's Avatar
300C has this option in their cars. You can turn on the HID when you use the keyless.
Old Aug 24, 2007 | 11:28 PM
corey415's Avatar
Turning HIDs on and off will shorten the life of your ballast and bulbs. Just an FYI.
Old Aug 25, 2007 | 08:20 AM
LowBUDGETs2k's Avatar
yea you probably dont want to flash the hid with the alarm but if u wanna damage them you can do so...but its all in the install and programing
Old Aug 27, 2007 | 11:51 PM
03DSM-RSX's Avatar
the Fit does not come with HIDs stock, so its not built with the stock charging system to handle the shock, nor is the aftermarket HID kit.
its one of those things where u can, but should not do.
linnboi
25
Oct 4, 2012 10:21 AM
Neal84
Jul 8, 2011 01:57 PM
Darkhope
Oct 14, 2008 09:10 PM
Biven5
Apr 23, 2008 03:49 PM
and1baller7k
Nov 18, 2007 05:02 PM
