Bigger Throttle Body
Old Aug 27, 2007 | 05:40 PM
kimo's Avatar
Has anyone install it.
Old Aug 27, 2007 | 06:12 PM
alf74's Avatar
of course....
I've tryed a BMW throttle body 68mm (drive by wire). It's a Bosch TB with the same contacts...
After installing It you'll think you are driving a diesel...
Old Aug 27, 2007 | 07:04 PM
Fit of RAGE's Avatar
tagged for interest
Old Aug 27, 2007 | 09:18 PM
George02's Avatar
Originally Posted by Toy Yoda
tagged for interest
X2 DIY??? or part number????
Old Aug 28, 2007 | 03:10 AM
alf74's Avatar
I'll show you my secret weapon!!!!!
Fit and Jazz throttle body (drive by wire) are made by Bosch....
they are like this:
**BRAND NEW**Porsche Cayenne S/Turbo gen. throttle body bei eBay Porsche, Car Parts, Cars, Parts Vehicles (endet 26.09.07 14:43:59 MESZ)
They have the same contacts....
audi, bmw and usually cars made in Germany use Electronic Throttle Control (Drive By Wire or Fly By Wire)
The only thing you have to check is its voltage 0-5v.
Then you have to build a connection from your standard TB to larger TB.
It doesn't matter if you won't find water circuit on new TB...
Old Aug 28, 2007 | 02:01 PM
kimo's Avatar
Is that your secret weapon.
they are like this:
Old Aug 28, 2007 | 03:26 PM
alf74's Avatar
Really I have many others....
Old Aug 28, 2007 | 03:35 PM
JDMchris.com's Avatar
I run THIS
can you do a writeup on exactly what is needed to be done, and before/after results of how it feels?
Old Aug 28, 2007 | 04:06 PM
805FitSport's Avatar
with out engine management installing a bigger TB would be a waste of time and money... we need a tunable ECU for the Fit
Old Aug 30, 2007 | 10:22 AM
alf74's Avatar
Really I'm not good at writing writeups, but I'll try...
Bosch Electronics Throttle bodies have the same holes attack.
There are two main differences:
- internal diameter. You'll find about 55mm on intake side and about 68mm on new TB. At this point you have to build a connection between intake and TB, with a diameter that passes from 55mm to 68mm. You can use plastic or wood or other materials.
- external diameter of TB. It's the bigger side where you have to fix air filter pipes
Maybe you'll have to bypass water cooling on some TB....
I wish my explanation is quite clear
I'll post some pictures as soos as I can.
Anyway it's a very easy DIY
PS: Regarding a tunable ECU it's true. I use APEXi SAFC II and a different ignition, but I think that a larger Tb with a good exhaust should work fine...
Old Sep 2, 2007 | 07:52 PM
azkikersfit's Avatar
I got the spoon throttle body on mine and it feels great and u actually feel the difference, i didnt need to tune the ECU but i guess tuning would probably improve its current status.
Old Sep 2, 2007 | 08:36 PM
kimo's Avatar
I have bored mine at the machine shop, wasn't done like Spoon but felt diffrence and it only cost me $5.
Old Sep 3, 2007 | 02:43 AM
alf74's Avatar
So you can imagine the difference between 60mm and 68mm....
Old Sep 3, 2007 | 02:55 AM
jeimusu86's Avatar
nice job...so do u want to do mine for me lol
Old Sep 3, 2007 | 04:04 AM
kimo's Avatar
Too bad I live far away from LA
Old Sep 27, 2007 | 04:44 AM
jazzista's Avatar
Ciao,
are you working on a 1.4DSi or 1.2DSi?
Stefano
Old Sep 27, 2007 | 04:58 AM
alf74's Avatar
Ciao Stefano
I have a 1.4 iDSi (L13A).
Really I took larger Tb out because I installed an lpg system and Brc technician asked me to put on the original TB....
Old Oct 2, 2007 | 06:18 AM
jazzista's Avatar
Ciao Alf74,
what a pity How was responding your Jazz to the larger TB?
Stefano
Old Oct 5, 2007 | 01:07 PM
Kostas's Avatar
.... I installed an lpg system....
Hi friend.
Please can you bring some pictures about LPG kit?
I have already post there: https://www.fitfreak.net/forums/fit-...-lpg-fuel.html
[Mods: sorry about off topic, i will delete it soon]
Old Oct 6, 2007 | 05:29 AM
alf74's Avatar
I've to take some pictures of my car as soon as I come back home....
Marrk
Sep 14, 2013 01:25 PM
Remould
May 29, 2012 11:39 PM
phoenity
Mar 15, 2007 11:57 PM
alf74
Jul 25, 2006 02:30 AM
kimo
Dec 20, 2005 04:12 PM
