New Fit "pulsing" while stopped
Old Sep 20, 2007 | 01:16 PM
Telix's Avatar
My Fit started to "pulse" while stopped at lights. (It's an AT so it's not in neutral.) If I put it in neutral the pulsing goes away. The brake pedal is fully pressed, but it just pulses strangely, it feels like the engine is trying to rev a very small amount in a cyclical fashion.
Should I be concerned? It definitely feels unusual.
Old Sep 20, 2007 | 01:20 PM
TOOL's Avatar
Mine does the same exact thing, just have to get used to it or put it in nuetral when stopped.
Old Sep 21, 2007 | 04:32 PM
Steeldog's Avatar
Is it something new, that the car didn't always do?
And it isn't the cycling of the cooling fan? Mine starts that cooling fan bidnih as soon as I start it, even though the engine's cold.
Old Sep 21, 2007 | 06:30 PM
naszero's Avatar
I'm pretty sure it's the A/C. I thought all cars did this?
Old Sep 21, 2007 | 06:35 PM
Cat's Avatar
Cat
Yup! It may be the fan it seems to kick in at a stop and sounds like a rev.
Cat :x
Old Sep 21, 2007 | 07:59 PM
Whitehybrid's Avatar
oooooor, its idle sugre...
i have no pulse/surge at stop lights...and anyone that does and chooses to ignore it, is in fact ingnorant...do you physically see your rpms raise and lower? thats the question, your body doesn't come with a CEL so i can't judge you...
Old Sep 21, 2007 | 08:25 PM
grouser's Avatar
Do you have the defroster on by chance? Cuz with it on the AC will cycle on and off causing an uneven idle.
Old Sep 21, 2007 | 11:05 PM
Telix's Avatar
No the A/C isn't on and there isn't any actual RPM surge on the tach. And it appears to have gone away lately. Now I'm noticing the fan spinning up following a stop. I'm probably just noticing the weird things about new cars each day.
Old Sep 22, 2007 | 12:50 AM
Steeldog's Avatar
Yep
I bet that's what it is, too. This car does have a lot of little sounds and stuff that you might not notice in a larger / heavier car. Especially if your last car was not a Honda. Hondas have a few quirks like that, but it all works together to make very good vehicles.
Old Sep 22, 2007 | 02:39 AM
storm88000's Avatar
Frequent FitFreak Poster
Odd, mine just started doing this too now, I have a manual and it does it in neutral at stoplights. I have 20k miles.
Old Sep 22, 2007 | 08:25 PM
grouser's Avatar
No the A/C isn't on ......
let me clarify,,,is the DEFROSTER on? Cuz the AC is used to defrost the window. Glad it went away for u
Old Sep 23, 2007 | 11:17 PM
TOOL's Avatar
No the RPM guage stays still, i think it may be the AC...ill check and do a test...
hogwylde
Sep 29, 2011 02:44 PM
FELIXY69
25
May 21, 2010 04:35 AM
newfitguy
Jul 29, 2008 08:58 PM
seedbean
May 1, 2007 04:57 AM
Mugen_Dom
May 13, 2006 10:18 PM
