weight of stock 15 alloy wheel?
Old Sep 22, 2007 | 08:12 PM
VistaXP's Avatar
Anyone know how many lbs the allow wheels are for the honda fit sport?
Old Sep 24, 2007 | 01:40 AM
storm88000's Avatar
Frequent FitFreak Poster
They weight about the same as a Toyota Yaris.
Old Sep 24, 2007 | 02:49 AM
VistaXP's Avatar
Uhhh, okay...
I need numbers.
Old Sep 24, 2007 | 03:15 AM
User Name's Avatar
The search feature is magical........and don't say it doesn't work, I just did it.......
Old Sep 24, 2007 | 03:51 AM
BBRFit's Avatar
well search has already been brought up so I guess I got nothing
knowing is half the battle
Old Sep 24, 2007 | 08:41 PM
storm88000's Avatar
Originally Posted by VistaXP
Uhhh, okay...
I need numbers.
That was a joke, as in - they are heavy.
Old Sep 24, 2007 | 08:59 PM
Gary K's Avatar
well the 16" HFP bronze Honda Alloys wheels are 18LBs..if that helps.
Old Sep 25, 2007 | 12:19 AM
Tork's Avatar
weighed one on my digital scale last spring. Forgot exactly, like 16.5-17 lbs as I remember
Old Sep 25, 2007 | 12:35 AM
LOW BUDGET's Avatar
It was weigh on a digital weighing machine long time ago and it weighs between 35 lbs - 36 lbs with a tire included.
Old Sep 25, 2007 | 11:30 PM
methodbasic's Avatar
17lb rim + 19lb tire = 36lbs.
Someone get me some lightweight tires.....
Old Sep 26, 2007 | 12:51 AM
Mr B's Avatar
On a digital scale, I just weighed the stock 15" with the Dunlops to be 34.4lbs while I was at Endless testing out their kit. Pretty light setup for stock wheels.
Old Dec 16, 2007 | 12:37 AM
MINI-Fit's Avatar
For Dunlop SP 31 A/S (passenger All Season tire)
Tire Specs for Dunlop SP31 A/S
195/55-15 tires should be 18 lbs each
so 34.4 -18= 16.4 lbs.
Other estimates have it at about 15.5 to 17 lbs each.
Of note if you like to autocross and need stock sized wheels at lower than stock weight and low price (nearly stock offset)
Then tirerack.com has-
Sport Edition D4 15x6" +50 mm offset $59 each (closeout) 14 lbs each
Silver finish, 1 year warranty, made in china. 1 piece Cast construction
Likely going to be discontinued since closeout. Rims made by Kosei, they are raising their prices so tirerack isn't going to keep them.
You can pay a lot more and get 15x6 rims very light about 9 lbs each and fairly strong (forged construction). Some are as much as about $400 per rim.
For moderate price-
Enkei Racing Series RPF1 $199 each 15x7" +41 mm offset 9.5 lbs each
1 year warranty, Made in Japan, 1 piece gravity cast with MAT technology
Wheel Tech - Wheel Construction
Bright Silver Paint.
Old Feb 20, 2008 | 08:20 AM
john trials's Avatar
A friend of mine just measured a 2008 Fit Sport rim (with the TPMS valve stem attached) on a VERY accurate scale at his work.
17.45 pounds.
Old Feb 20, 2008 | 12:06 PM
TOOL's Avatar
17.45 pounds.
Wow thats heavier then i thought?
Tyler
Old Feb 20, 2008 | 12:08 PM
Tofuman's Avatar
14" wheels on the base FTW...
Kosei K1 TS
14x6
Weight: 9.3lbs.
$104 each.
Old Jun 23, 2008 | 05:09 PM
roweraay's Avatar
17.45 pounds.
I think this is roughly the same weight as the 17x7.5" BBS wheels on my Subaru WRX. But I guess for a reasonably priced OEM set, this is okay.
hayden
May 4, 2014 02:49 AM
qbmurderer13
Jan 4, 2010 08:46 AM
Pedalpusher
Sep 12, 2008 03:27 PM
Skimmer
Sep 26, 2007 02:52 PM
lasersailor
Oct 25, 2006 11:30 PM
