tips for new user
Old Oct 17, 2007 | 10:44 AM
bozerwong's Avatar
tips for new user
Any maintenence tips or advices for first time car and fit owner?
Thank you.
Old Oct 17, 2007 | 11:01 AM
Hocker's Avatar
Senior Member
Not sure what you mean
Keep the oil changed every 3k or so...It's not several years old to know what the common problem areas are and most don't even have that kinda mileage yet here in the states.
Old Oct 17, 2007 | 12:15 PM
bozerwong's Avatar
this morning when i was starting my engine, i got the cold engine signal and it was turned off after 2 minutes or so. Is it common to have a cool engine signal after a night? but it wasn't all that cold last night (50F ish)
Old Oct 17, 2007 | 01:17 PM
junior40er's Avatar
Yes ,its normal. It do that even after not using it for couple hours. It's there so engine can warm to normal operating temps before you get on it. Also, allows relubrication thoughout the engine since oil will settle in oil pan after a while. I always let that light clear before driving. It's just good practice on taking care of your car and making sure it'll last 200K+ miles.
Old Oct 20, 2007 | 02:37 PM
sortanewinatl's Avatar
Do your maintenance....
Oil/filter change every 5k or so. I've always used Mobile 1 synthetic; it costs more, but I think it's worth it. (I put over 300K miles on one of my cars and it still ran great when I traded it in).
Fuel filter every year.
I flush and fill the cooling system every other year (maybe every year if you're in a really cold or really hot climate)
If your unfortunate enough to own an automatic, change the fluid/filter every year.
Make sure the CV joints are in good shape, chassis lubed, etc.
Never pay to have your rotors "turned". Just replace the pads BEFORE they wear complely out, and replace the rotors with every other set of pads.
Old Oct 20, 2007 | 11:59 PM
pip_rocks's Avatar
i bet a lot of us on here actually like our automatics.
maybe i should start a poll.
Old Oct 21, 2007 | 01:32 AM
rushlow's Avatar
There isn't anything wrong with auto's. They are extremely convenient.
I got a manual because it is more fun to drive for me, but I wouldnt say people with autos are "unfortunate"
EDIT: oh and you might want to invest in some sort of protective clear film stuff that goes on the hood,bumper and mirrors. I didn't get this on mine and I wish that I did, because I have looooots of little rock chips on my hood that make me sad.
Last edited by rushlow; Oct 21, 2007 at 01:36 AM. Reason: forgot to answer thread question...oops
Old Oct 21, 2007 | 03:41 AM
F0NIX's Avatar
The manual for my Jazz 1.4LS CVT say that you should change oil every 20.000km (about 12.000miles). If that correct then I think changing oil every 3000 or 5000 mile is a bit early...
I do'nt have a oil-life indicator on my Jazz. It is just stated in the manual how often you should change. And it says every 20.000km or once a year, whichever comes first. I am passing 16.000 km mark soon, and I have had the Jazz since february 2007 (about 8 month).
Old Oct 21, 2007 | 05:25 AM
KayJai's Avatar
Hrmmm, I should check mine too, since we have the same 1.3L with the CVT
Once I figure out the Japanese, I will report back
Old Oct 21, 2007 | 09:37 PM
Not sure about the CVT's (we don't get them here), but virtually all conventional AT's have a 12K Mile/12 Month interval for the fluid/filter change. I wouldn't be surpised if the interval is shorter for the CVTs.
AND... AT's cost more to buy, cost more to maintain, cost more to drive (lower MPG), and have a MUCH higher failure rate than a MT. So, if the convenience of an AT offsets all of that, then I suppose, for you, it's not unfortunate... but it certainly would be for me. Besides, you dont really drive an AT... you just steer it
Old Oct 21, 2007 | 10:14 PM
pip_rocks's Avatar
i dunno, i gotta stick up for all the auto folks out there who don't really care about swapping out their engine and lowering it and everything.
i'm on here because i think it's just an all around great car, even though i have no plans to heavily mod it or anything. if that makes me less of a fitfreak then so be it
Old Oct 22, 2007 | 11:44 AM
bozerwong's Avatar
so how often do you guys do oil change for your fit? and what in the manual states that?
carolina_cruising
Nov 13, 2013 07:09 PM
hondafit_03
Aug 13, 2011 11:05 PM
clicq
Jun 29, 2011 07:18 AM
parkerdt
Nov 9, 2009 07:15 AM
mozarwasagenius
Feb 16, 2009 09:33 PM
