Fit: Road Noise
Old Dec 24, 2007 | 05:52 PM
FrankieY18's Avatar
Fit: Road Noise
Thinking about buying a 2nd car in the family... From the consumer report, the only con about Fit is the road noise. What do you guys have to say about that? Is this a big problem?
Old Dec 24, 2007 | 05:58 PM
AppleMac*Fit's Avatar
There are lots of threads on reducing the road noise here. I do not think it is a big deal. HOWEVER - I have also spent some time making some serious reductions in road noise. Check out some of the threads in Fit Interior forums
Old Dec 24, 2007 | 07:15 PM
Snap Fit's Avatar
BIG problem?
"No" with a capital NADA.
If that was its only "con" then I kid you not just about everyone facing this side of the lighted moon would buy one, or two, or three of em!
Our Nissan Quest is louder than the fit, my old 01 civic is about the same, my old 86 civic was WAY louder, you do notice some noise mostly road on an unkept route and engine when "gunning" it.
Thats actually good that you read that report! As that is hardly a complaint, you would be pleasantly surprised checking one out with the idea of it being "noisy" as you probably will find it not so much loud.
Old Dec 24, 2007 | 11:20 PM
MINI-Fit's Avatar
Depends a little on the roads.
Not really a big problem on most roads.
I have 2006 Honda Civic Sedan and that is a little less noisy then my Fit Sport both with Auto transmission and stock tires.
If you do wear out the stock tires you can always find replacement tires that would be more quiet- usually makes a difference.
Old Dec 25, 2007 | 12:20 AM
one of the noiser cars ive had, but do 95% surface roads on this
car (under 55mph) it's not bad at all.
Old Dec 29, 2007 | 09:21 PM
prelude_guy97's Avatar
If you find the road noise is bugging you....just crank up the stereo. :D
Old Dec 29, 2007 | 10:22 PM
kusojiji's Avatar
I think the Fit is noisy. It gets a lot of road noise tranmitted through. There's a little bit of engine noise, but most of it is from roads. If I'm running on concrete or whatever the freeways are paved with, it's bad. On asphalt, it's not too bad.
I've reduced a lot of it with foam and the dense stuff on the door panels, under the door panels, under the floor mat in the rear, and under the spare tire. But, it's still kinda loud. I did get more bass out of the stock stereo after all this stuff was installed.
I've read that the stock tires are notorious for noise. Dunlop SP37 or something.
Old Dec 30, 2007 | 07:18 PM
kusojiji's Avatar
I took a ride today after doing some mods per AppleMacFit's recommendations in his Fit Inside threads. There is quite a bit of engine noise after all.
Mister Coffee
Nov 27, 2014 10:29 AM
pipcorona
Jul 16, 2014 06:10 AM
Eamper
Mar 11, 2011 07:27 AM
DrewBird
Sep 19, 2007 11:13 PM
