Front Park Lights and Signal Lights swap/switch rewire
Old Jan 23, 2008 | 01:16 AM
GDLover's Avatar
I'm new to the modding scene. I'm mostly doing simple installs and just get someone else to do the bigger stuff. But this project I have in mind (after seeing Siphon's Winter Issue) of switching the park lights and the signal light has been bothering me. I want to see it done and I think it *may* look cool. Any advice on how that can be done? Any DIYs you know that this switch has been done with already?
Any help is much appreciated.
Old Jan 31, 2008 | 01:48 AM
j5ive's Avatar
so you want 4w wedge bulb turn signals no one can see and constant on 21w parking lights in that tiny housing to overheat and turn the lense brown?
easy to swap wires, but terrible idea.
Old Mar 11, 2008 | 11:36 PM
FitRigger's Avatar
check out this website for the swap.
Having A Fit: How-To Guides
I'm not so sure about the reflector housing turning brown because those lights are swapped overseas. But I guess you could just change to a different bulb that doesn't emit as much heat.
Old Apr 4, 2008 | 11:36 PM
GDLover's Avatar
Thank you!
I'm thinking LED bulbs would be my answer.
Old Apr 5, 2008 | 02:10 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Youre going to have rapid flash when you use the signals, unless you add a resistor.
And people will barely notice your turning.
WhEreZmYFiT
25
Mar 21, 2016 06:20 PM
Orcshine101
Jan 15, 2012 02:16 AM
90crxfreak
Sep 2, 2010 12:38 AM
SCBarren
Nov 30, 2009 10:21 PM
andeezfit
Sep 22, 2009 01:58 AM
