Offset help....
Old Mar 3, 2008 | 10:31 PM
SYMBIOTIX's Avatar
Offset help....
Hey lads, I am trying to figure out if I'll be ok running 16x7" wheels with a +38mm offset in place of my factory 15"s. I plan on using a 5mm spacer (w/out studs) or a 10mm spacer with studs. However when I ran my calculations through an offset calculator here are the result I got:
"You will have 4mm MORE clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 30mm"
I entered the new wheels as 205/45/16's.... Will I really have 30mm difference on the outside?? Doesn't seem right to me?
Anyways the offest calculator I used is located here, feel free to play around with it:
10mm Spacer for the Rear: H&R, Eibach, or Rouge E?? - BMW 3-Series (E90 E92) Forum - E90Post.com
-P@
Old Mar 4, 2008 | 08:28 AM
you're going to rub the inner fender with those wheels/tires.
are you rubbing your struts or c/o's?
for 16x7 running 205/45/16's, depends on the tire you get, but
i would try to keep it +45 range on the offset, given that you're
not rubbing your aftermarket struts or c/o's.
Old Mar 4, 2008 | 08:35 AM
SYMBIOTIX's Avatar
Damm it looks like Im limited to slipstreams then .... Not that thats a bad thing. Thanks for your help, and your response is exactly what I thought based on peoples statements around here... That offset calculator is a piece of garbage, it told me the opposite :S
Old Mar 4, 2008 | 06:49 PM
SYMBIOTIX's Avatar
The wheels with the 38 offset should be fine with a 10mm (or even 5mm) spacer though right??
My drop will be GF210
Old Mar 4, 2008 | 06:52 PM
TOOL's Avatar
You will rub. But it will be fixable i belive.
Read this-
https://www.fitfreak.net/forums/fit-...heres-how.html
Tyler
Old Mar 4, 2008 | 06:54 PM
JDMchris.com's Avatar
I run THIS
why would you add spacers? that will lower the offset and you will rub like a madman.
Old Mar 4, 2008 | 07:02 PM
TOOL's Avatar
My thoughts exactly.
Tyler
solbrothers's Avatar
with those wheels/tires, you don't need any spacers. that's what i have, and i had to do the fenderliner trick on the front to stop the rubbing, as the offset is too LOW.
Old Mar 4, 2008 | 07:05 PM
SYMBIOTIX's Avatar
10mm spacers add to + offset right?
Well if this is the case then according to this calculator I will lose 2mm of clearance on the suspension side if I rock 205/45/16's on a 38 offset with a 10 mm spacer...... Is this not correct??
Wheel / tire size calculator / comparer - BIGCUSTOMWHEELS
Where the hell am I going wrong here???
Old Mar 4, 2008 | 07:10 PM
TOOL's Avatar
Spacers will push the wheel out, dropping the offset. The lower the offset the more the wheel sticks out, the higher the offset the more the wheel is sunk in..
Tyler
Old Mar 4, 2008 | 07:59 PM
SYMBIOTIX's Avatar
10-4 Thanks guys. I was under the impression that spacers added to offset.
Old Mar 14, 2008 | 08:05 AM
mahout's Avatar
They will rub with 38 mm offset even without spacers. Spacers reduce the offset by the thickness: hence 38 mm wheel with 10 mm spacer = 28 mm offset. You won't just rub you wil hammer.
EMC2
Apr 29, 2024 12:20 PM
mikeGe82012
May 28, 2017 12:11 AM
08_vbp_fit
Dec 16, 2016 01:56 PM
jazz_do_it
Feb 14, 2010 09:09 AM
diedwater
Feb 23, 2008 04:12 PM
