rear wiper blade
rear wiper blade
anyone replace the rear wiper blade if so what size and where did u get ..
what brand ...i went to replace today and guy said the michelan and other brands have too small of bar that the wiper arm fits onto blade
I was at WalMart today, picked up a 14" wiper blade as this is the replacement size for the rear. Turns out swapping it for the original Honda blade is not possible as the connector area is different. Returning it in the morning and buying one directly from the Honda dealer. I have replaced the front blades with RainX brand, works better than the factory ones. Real sweet.
The entire rear blade including rubber/plastic assembly is something like $26 CDN. Just the rubber blade, which slides into the original plastic wiper assembly is $5.75 CDN. You need the two metal strips from the old rubber blade, switch them over to the new unit. Takes two minutes.
The Honda parts guy told me the front wipers are together something like $140 CDN if they need replacement. That is just for the plastic and rubber sections and not the arms. Of course we can replace the same parts for $30-50, depending on quality from Walmart.
So do not throw out those front or rear plastic blades or the metal strip holding the rubber blade in place.
So do not throw out those front or rear blades.
When the rear wiper rubber started to peel away I tried to find the same size at Can Tire. Not finding any I cut an old wiper blade with a plastic mount I had and with a little fiddling it is doing yoeman duty on the rear.
Can someone tell me if this means i need new blades?
-streaks
-noiseless
-window still blurry (with defroster on yes)
-lights are "streaky" and looks brighter/powerful than it really is
If it doesnt mean i need a new blade, wtf am i suppose to do? its annoying -.- i dont want to use a liquid rainx that i had used before, it turned out hazy and foggy big time
-streaks
-noiseless
what u can try is some light grit sand paper on the blade partthat touches the window rub it few times then clean blade...then make sure it is seating good on the windows..might have to bend the wiper blade arm a hair to make better contact
-streaks
-noiseless
-streaks
-noiseless
Use distilled white vinegar. You can dilute the vinegar 2:1 with water. Heavy spots may require pure vinegar. Either way, the vinegar will not harm you or your car.
Do you use Armour All or a like dash protector? The interior windows could use a good cleaning as well.
And finally, when was your last eye check-up? Really. You will notice lights at night tend to be an issue if you are in need of glasses. If it has been a year, time to see an eye chart.
-streaks
-noiseless
-streaks
-noiseless
I hope you are NOT using RainX regular on your interior windows, this is a major NO-NO. You need the special Anti-Fog Rain-X and not the regular stuff.
Using the window squeege at the gas pumps? Not cool, tons of oil and dirt on those STD spreaders. Could be where you picked up the exterior oil issues on your windshield. Stay away from the anything near the gas pumps.
Rubbing Alcohol also works at removing window film, use a good window cleaner afterwards inside and outside.
kkim
Jan 9, 2025 02:36 PM
12vltfrk
Dec 2, 2010 12:06 PM
