Radio wiring harness question
Old Mar 16, 2008 | 10:58 AM
mrob's Avatar
I received the radio wiring harness in the dash kit from Scosche (part # HA10B). The harness has the blue/white "remote turn on" lead. I thought that the remote turn on signal is supposed to be supplied by the HU...since it's supposed to go hot when the HU is turned on. So why is the lead in the harness? I don't see how it could toggle on and off with the HU if it's supplied by the Fit and not the HU.
I know I'm missing something. Could someone set me straight?
Thanks,
Mike
Old Mar 16, 2008 | 01:20 PM
Injundon's Avatar
Hi Mike, Other hondas like the civic Si Which has an amplifier use that same harness. You need to hook up the power antenna wire though. (solid blue) otherwise AM reception will be nil and FM wo't be o good either.
Old Mar 16, 2008 | 02:33 PM
mrob's Avatar
Thanks for the reply Donald. Okay, when I posted my message, I had just read the description of the color codes on the back of the bag the harness came in. But looking at the actual wires on the harness, the blue/white lead isn't really there. I guess the color codes on the bag is an "all inclusive" list of color codes. I also have the antenna adapter, and that bag has the same complete list even though there are only two leads (the antenna and the antenna power).
Now, taking an inventory of the actual wires on the harness, I see that there are some colors that are not mentioned in the color codes. Does anyone know what these colors mean?:
-Brown
-Orange/Black
-Orange/White
-Pink
Thanks,
-Mike
Old Mar 16, 2008 | 04:34 PM
Injundon's Avatar
Bwon is cell phone mute.
Orange/black is negative dimmer
Orange/white is Positive dimer
Pink is VSS
Depending what head unit you have you might need one of the dimmer wires..the rest are not needed.
Old Mar 16, 2008 | 07:18 PM
mrob's Avatar
Great...thanks for the info!
Old Mar 17, 2008 | 01:51 AM
CuTeBoi's Avatar
He may need the pink one, why even remove any of them...
Old Mar 17, 2008 | 02:49 AM
smatts's Avatar
Honda Fit Forums Moderator
Anyone know what cell phone mute does? I don't think I hooked that one up when I installed my deck.
Old Mar 17, 2008 | 03:34 AM
Injundon's Avatar
the cell phone mute is for aftermarket blue tooth kits and oldschool car phones. When you get an incoming call, it grounds the wire and mutes the head unit.
Old Mar 17, 2008 | 07:43 AM
mrob's Avatar
Interesting. So where's the other end of the cell phone mute connection in the Fit? I'm assuming it's not currently connected to anything coming out of the factory.
In my case, I don't currently need any of those mentioned, but I'm not going to remove them. I'll just tape them off.
Old Mar 17, 2008 | 12:12 PM
Injundon's Avatar
Not used from the factory, and most aftermarket head units don't even have provisions for this anyhow, ince they all have their own plug in blue tooth kits.
Old Mar 17, 2008 | 12:28 PM
mrob's Avatar
That makes sense. Thanks for all of the great info!
Old Mar 18, 2008 | 04:09 AM
smatts's Avatar
Yeah my deck has bluetooth and when in phone mode it just turns the music off anyways.
Old Sep 2, 2019 | 02:03 PM
Jim Mckay's Avatar
Swc
Wich wire connects to steering wheel controls I have a 2007 crv pink brown green White stripe and black white stripe
Old Apr 29, 2022 | 08:14 PM
johnfit10's Avatar
2010 Honda fit sport back speakers has no sound
I just installed aftermarket double din in my 2010 Honda fit sport check everything, The front L/R speakers work but the L/R speakers have no sound. I need help wiring correctly.
thebluepotato
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
21
Mar 22, 2015 06:15 PM
clay7160
Jul 31, 2011 12:16 PM
JDMchris.com
Dec 26, 2008 11:27 PM
xwikedonex
May 25, 2008 11:19 PM
timster
Sep 22, 2006 01:43 PM
