ECU Reset
Old Mar 30, 2008 | 04:56 AM
Yongjin's Avatar
ECU Reset
Hi... I just change my intake today... the workshop said that just do a ECU reset will do no need to tune even if I change the exhaust in future.... new setting will be learn when I put the battery back....
Got 2 quest... hw do I truely reset the ECU just remove the battery neg connect or possitive connection or both
Antoher is what the workshop saying true
Old Mar 30, 2008 | 11:38 AM
claymore's Avatar
They are correct the ECU has enough learning in it to adjust for new intake and exhaust.
Just disconnect your negative battery cable for 10 seconds or so (no need to time it) put it back on and go for a drive. If you normally drive pretty hard and fast do that for a few days so the computer can determine normal operating conditions (the way you drive) for your setup. After a few days drive anyway you like.
Old Mar 30, 2008 | 04:08 PM
goodyonsen's Avatar
That's good advice.
Old Mar 30, 2008 | 05:26 PM
Hondasforlife's Avatar
very good advice..weapon r told me the same thing..by the way what kinda intake did you get??
Old Mar 30, 2008 | 09:24 PM
Yongjin's Avatar
icic... okiez.. thankz...i do tat aft my 20k svc and pump full tank..
i put in t1r carbon....
thepaperescape
Jun 4, 2018 07:22 PM
naylynnaung
Feb 20, 2016 06:39 AM
Trainman
Jul 19, 2012 12:56 PM
jenos
May 20, 2011 10:48 AM
mcrobie
Nov 25, 2010 11:50 AM
