Air Conditioner Blows warm to hot air
Old Aug 1, 2005 | 07:30 PM
tileguy
Guest
Posts: n/a
Hello, I have a 1995 Honda Accord, 4 cyl, 2.2 ltr, and just put in a new
radiator. Everything went well, except my air conditioner blows warm to
hot air, everything worked fine prior to changing the radiator. Is there
something I missed?
Professor
Guest
Posts: n/a
Re: Air Conditioner Blows warm to hot air
Is the compressor running?
Professor
www.telstar-electronics.com
Old Aug 2, 2005 | 02:41 PM
Todd K.
Guest
Posts: n/a
Check both fans behind the radiator when the AC is running. Are these
blowing a good amount of air?
Old Aug 2, 2005 | 08:30 PM
motsco_ _
Guest
Posts: n/a
> something I missed?
If it blows ANY air that is warmer than the outside air, your heater is
ON, so you need to fix the cables that turn the heater on. I'm sending
you a document that shows the adjustments. The 'tap' under the hood may
just be staying on a bit, if it's at all like my '98 Odyssey. '95
Odyssey was the same.
'Curly'
Old Aug 3, 2005 | 05:39 PM
butch burton
Guest
Posts: n/a
Same thing happened on my 97 accord - the repair guy pulled apart the
plug that turns on the AC compressor - actually it causes the clutch to
engage thus spinning the compressor. Simple to see if the compressor
is turning - open the hood with the motor running and ac off - look at
the center of the ac compressor and see if that thing is spinning - it
won't be with the ac off. Then turn the ac on and look again - if it
is not spinning - then the clutch is not engaging.
If the above - trace the wire from the ac and on mine it went to near
the side of the radiator into a connection and it was that connection
that the mechanic did not get put back together. Hope that is all - at
first I thought his grunting and tugging lost a load of gas. The pig
also stole one of my maps - will have a bigger garage in my new house
and will be able to avoid guys like that for simple repairs - oh it
took 3 different radiators before we found one that would not leak -
Bumper to Bumper Hecho in Mexico. Oh they used the old drain plug - it
leaked - had to go buy a new one. $375 or so but the dealer wanted
over $600.
Let us know what u find - hope it is a simple electrical connection not
being made.
Mshellt
Jul 12, 2016 04:23 PM
lknbigfish
Oct 29, 2014 10:16 PM
GTRPLYR
Jan 18, 2012 04:00 PM
myc0p
Aug 25, 2011 12:04 PM
JKR
Aug 28, 2006 09:20 PM
