Removing center panel lower cover?
Old May 8, 2008 | 11:02 PM
Y0ssar1an's Avatar
Hi,
I'm in the process of removing the factory stereo following the musiclink instructions here:
http://www.handa-accessories.com/fit/musiclink.pdf
I'm stuck on step 6, removing the center panel lower cover, specifically releasing the right clip. Looking in from the side I can see a white tab in the likely position. I've tried pressing down (and sideways in case it's a bayonet), and while I see the cover flex slightly, I've just not been able to pop it out. Can anyone offer any pointers on what I should be doing? I assume, by the lack of any results from searching, that it shouldn't be particularly difficult.
A photo of the cover removed would be really helpful so I could work out what I'm dealing with.
Thanks, B
Old May 8, 2008 | 11:17 PM
Rod2Rice's Avatar
I took that panel off the other night, in the far outer ends of the panel, I just slid a small scredriver in from the front and gently used it to pop the clip, came off fairly easily. There are scans of other instructions linked in another thread in this section.
Old May 8, 2008 | 11:21 PM
edjosh23's Avatar
You should be able to just put a screw driver at the front of the panel and pop the pannel out.
Josh
white_FIT2012
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Apr 25, 2015 07:40 AM
dennison
Jan 14, 2013 04:16 PM
Phrost
May 8, 2009 11:54 PM
Inmyrem
Mar 12, 2009 05:24 PM
Inmyrem
Oct 30, 2008 06:04 AM
