1990 civic wagton overheating?
Old Aug 7, 2005 | 04:43 PM
theo.chan@gmail.com
Guest
Posts: n/a
OK, so I had a problem with overheating a week ago, and it turned out
the head gasket was gone. After having my mechanic clean out the
engine, adjust the timing, and replace the head gasket, everything was
fine and I made a 700km trip with no problems at all. One thing I did
notice was that my fuel consumption was up significantly (18mpg down
from 26mpg).
I was driving around today (regular speed, and regular outside
temperature) and all of a sudden smelled this rotten fish kind of
smell. Right after smelling this my engine temperature went way up to
the red, and stayed at the red for a few minutes before going through
the roof.
Opening up the engine and checking it, there was some sort of leak or
explosion of oily water all over the engine compartment. The oil and
coolant levels are ok, and the radiator fan comes on, but the radiator
itself is cool. On the way back home, the car stalled going up a big
hill (from about 2000rpm) for a second and then started again. After
parking the car, the engine would emit lots of white smoke when trying
to start, and wouldn't catch unless I added gas or roll started it. Any
ideas what the problem is and how much it might cost to fix? Could it
be something with the water pump?
Thanks!
Theo
Old Aug 8, 2005 | 11:48 AM
Bruce
Guest
Posts: n/a
Re: 1990 civic wagton overheating?
hmmmm... the rotten fish smell is a new one on me. ???
You said coolant and oil levels are OK, but is there any
cross-contamination? Oil in coolant looks like a chocolate milkshake,
should be evident on dipstick or on the inside bottom of the oil filler
as a moyonaise-like froth. If this is the case, the new gasket has
failed.. maybe warped head, improper torqueing of the head bolts, etc.
Ask your mechanic if he checked the mating surfaces of the head and
block for warpage.
The cool radiator sounds like the thermostat is backwards, or maybe
stuck? Ask your mechanic if he changed this.
The bad mileage could be from your timing belt being a tooth off,
however when my old Toyota was a tooth off, it ran rough.
Good luck,
-Bruce
Bruce
Guest
Posts: n/a
cross-contamination? White smoke out of your exhaust is almost always a
blown gasket. Oil in coolant looks like a chocolate milkshake,
cap
block for warpage.
Good luck,
-Bruce
dominating013
Apr 28, 2018 01:38 PM
mat77
Jan 12, 2017 09:48 AM
romansprott
Oct 13, 2014 12:01 AM
jdachinh@yahoo.com
May 21, 2006 11:32 AM
john_williams1000@hotmail.com
Oct 19, 2005 02:32 AM
