Auxilary Vent directly on the Intake Manifold?
Old May 19, 2008 | 05:02 PM
Sugarphreak's Avatar
Push My Button
Ok, crazy idea... looking for the pros and cons
Here is the theory
Ok, on my WR intake manifold I have a nipple with a plug right up near the throttle body. I was thinking about unplugging it and putting a tiny vent filter on it.
Why? For two reasons; First, I have a CAI and if I ever get hydro locked it may be enough to prevent the water from sucking up and reaching the engine. Secondly, my car lags worse than a turbo when you hit the gas because of the CAI. I am wondering if a little relief would improve the initial response.
What i don't know is if the car ECU will "freak out" because I am bypassing the throttle body.
Anyway, just a wacky idea. Comments?
Old May 19, 2008 | 06:50 PM
Injundon's Avatar
it'll mess up your idle and cause you to run a little lean, as well probably throwing a MIL/CEL. and won't effect water getting in at all. Just buy an AEM bypass valve if your concerned about water.
Old May 19, 2008 | 09:48 PM
underdog's Avatar
vacume leaks=big no no. especially on a map sensor controlled car.
Old May 19, 2008 | 11:31 PM
Push My Button
I figured as much, it just bothers me that this nipple sits there unused! I think it is for a boost gauge or something.
Old May 20, 2008 | 12:00 AM
quangalang's Avatar
bad idea it's just an unused vacuum source
Old May 20, 2008 | 12:14 AM
claymore's Avatar
Could be used for vacuum gauge.
LRPTEC
May 23, 2018 12:08 PM
MR-GE8
Oct 14, 2010 02:52 PM
bluerice
Apr 1, 2009 03:39 PM
DrKelso
Nov 4, 2008 05:23 PM
Nighthawk_GD3
Oct 29, 2008 10:22 PM
