Generic Subs / AMP !??!?
Old Jun 1, 2008 | 05:54 AM
cKranez's Avatar
alright soo i saw a co worker who also drives a fit he paid 260.00 for a JL generic sub / amp + installs.... it sounds pretty good also for a imitation.... but i was wondering is there any potential problems with it?.... why is it soo cheap yet it sounds pretty good?... just curious on the problems it might cause.... anybody have comments on this subject?
Old Jun 1, 2008 | 10:34 AM
Sloto200's Avatar
When it comes to subs and amps, your going to get what you pay for. The cheaper model stuff (in my experience anyway) tend to fail more often. Amps will overheat and once you over heat a cheap amp, there is really nothing you can do. It will usual have a complete failure soon after. Cheap subs are very easily blown as the voice coils are garbage. If you take care of them though, put the amp in a location with plenty of airflow and not in direct sunlight and not listen to it at very loud volumes, you should get some good use out of it.
Old Jun 1, 2008 | 06:49 PM
Injundon's Avatar
the issue mainly is very low quality construction. The components in cheapo amps are not anywhere near top knotch. ex 20% tolerance resistors, 10% tolerance caps, performance from 1 amp of the same model to the other can vary drastically. (like Rockford Fosgate Punch series amps. their "birthsheets" vary by up to 15%.)
So it leaves them more prone to failure, more prone to distortion, etc. etc.
For cheapo subs, well same issues. Poor quality constuction. Even entry level subs from some major brand names are like this as well. They literally just slap them together on a production line. VC alignment isn't always that great, Materials are whatever costs the least. Cones are usually too thin and prone to flexing (VERY audible disortion) and generally sound like crap.
Old Jun 1, 2008 | 08:44 PM
cKranez's Avatar
wow k nice thnx for the info...
Old Jun 1, 2008 | 08:45 PM
Injundon's Avatar
still yeah there's alot of inexpensive quality amps out there..there is no need to go flea market quality on things.
Old Jun 2, 2008 | 04:11 PM
cKranez's Avatar
is there anything around the 200 dollar range?... i saw a thread where you recommended the JL 10" for the sub under a bill.. but how bout a inexpensive amp or cab for the sub?
Old Jun 2, 2008 | 04:30 PM
Injundon's Avatar
I'll crutchfield you a great bang for the buck setup. however it's just to give you an idea..I always reccomend buying locally.
Alpine MRP-M450 Mono subwoofer amplifier 400 watts RMS x 1 at 2 ohms at Crutchfield.com
JL Audio CS110RG-W1v2 Sealed PowerWedge™ enclosure with one 10" W1v2 subwoofer at Crutchfield.com
it's the best bang for the buck setup you can find.. anythign cheaper and your just gonna be changing broken aprts in 3 months anyways
Old Jun 4, 2008 | 05:27 AM
cKranez's Avatar
a
nice thnx for the tips!
short1
Aug 11, 2013 09:49 PM
Jaivee
SoCal Classifieds
Apr 12, 2012 04:11 AM
Vash
Nov 9, 2011 07:11 PM
OhNineFIT
Oct 16, 2010 10:59 AM
PowerHungryFIT
Mar 21, 2009 08:00 PM
