Chip tuning for Jazz 1.5l, i-DSE ?
Old Sep 2, 2005 | 08:34 PM
ad2000's Avatar
Hello,
Someone knows where to buy Tuned-chip(Performance chip) for Jazz 1.5 i-DSE, 2005.
regards
Old Sep 3, 2005 | 02:09 AM
vividjazz's Avatar
Someone that Posts too much
http://www.powerchipgroup.com/index.asp
Claim they can boost the Vtec 1.5 from 81Kw to 93Kw and the dsi 1.3 from 61kw to 70kw but as the chip is soldered in (surface mounted) not socketed its A$890 and takes about 1-3 hours. Also claims increases torque.
As the 1.5 dsi is not sold in Australia they don't do a chip for it.
Old Sep 3, 2005 | 04:23 AM
ad2000's Avatar
Thank you
regards
Old Sep 4, 2005 | 08:17 AM
strepto's Avatar
The stock Jazz is tuned for optimal performance. You really dont need to change the stock ignition maps or fuelmaps unless you've done modifications to the engine. Ones a complete exhaust system, and a good intake is installed - you can tune that to squeeze out a few extra horsepower.
Old Sep 4, 2005 | 09:25 AM
vividjazz's Avatar
If the Jazz engine has been detuned in order to accept inferior grade fuel wouldn't the chip upgrade be necessary to allow it to run optimally on the highest grade fuels or would the standard maps cover from 91RON to 98RON and beyond?
The stock maps optimize fuel economy. Wouldn't remapping sacrificing a bit of fuel economy result in increased performance?
These are some of the arguments the chip makers run. They have a vested interested so who knows how true they are.
Old Sep 4, 2005 | 12:55 PM
strepto's Avatar
This is true to a certain degree, but with the kind of compression the stock Jazz/Fit is running, the need for high octane isn't really present. Every car is diffrent, and every Jazz is diffrent - and require independent tuning. For a CDi or TDi application a chip can work wonders - but for the Jazz/Fit, and most other Hondas - only a dynotune will yield good results.
Old Sep 12, 2005 | 10:39 AM
feargone's Avatar
Talking Anyone like to try powerchip?
If powerchip works as it claims to be in their report, it will do wonder. 890 AUD is all right for an increase of 9 kW. Anyone care to cry ?
What is dynotune by the way?
Old Sep 13, 2005 | 06:30 AM
vividjazz's Avatar
A$890 isn't much if your getting paid in Euros, Pounds or US$ but its alot for those of us earning A$.
A dynotune is a way of tuning your car by using a treadmill.
The dynamometer is used to simulate road conditions. It is particularly useful for diagnosing engine management problems on newer vehicles. Using the dynamometer enables the technician to pinpoint problems, for example inadequate fuel flow, poorly flowing injectors and ignition problems. The dynamometer is the only accurate means for setting up carburettor mixtures. Power readings can also be obtained to compare before and after tuning performance and gauge improvements from performance modifications.
Old Oct 3, 2005 | 01:23 PM
NvM's Avatar
NvM
I'm getting the chip fitted next week, so will post results of what happens :P
Old Nov 23, 2005 | 05:12 AM
kimo's Avatar
So what are the results
Old Nov 23, 2005 | 09:45 AM
MtViewGuy188's Avatar
Exclamation
I'm not sure if you want to install a different engine management chip on the L13A and L15A i-DSI engines, though. The design of the i-DSI engines aren't exactly the type that can benefit from a different engine management chip, since they're not designed as performance engines.
But changing the engine management chip on the L15A VTEC engine might be another matter, though.
Old Nov 23, 2005 | 09:50 AM
Jonniedee's Avatar
State side I've ridden in a few Turbo desiel trucks that have gotten the Power Chip treatment. MPG's do go down but for the most part a completely stock truck becomes a fire breathing monster with nothing other than electronics!
Gordio
Dec 8, 2006 09:47 AM
tony2006
Aug 27, 2006 01:47 AM
pappiccio
Dec 9, 2005 01:28 PM
macG
Nov 3, 2005 09:19 AM
zexshiro
Sep 29, 2005 08:22 PM
