Element 2004 - Transmission temperature gauge
Old Sep 7, 2005 | 09:31 AM
Chris
Guest
Posts: n/a
Honda Element 2004, autm.
My question is related to the temperature of transmission fluid.
Is it necessary to add a separate temperature gauge for transmission?
Or the tranny temperature is shown on the same instrument with coolant
engine instrument?
I tow a trailer which is at the maximum limit admissible and want to
be sure the transmission is not overloaded.
In the user manual is mention to check the temperature instrument when
towing. But even in such condition, the values displayed is the same
with or not towing.
Thanks
Chris
Old Sep 10, 2005 | 12:30 AM
ay98
Guest
Posts: n/a
Re: Element 2004 - Transmission temperature gauge
>engine instrument?
>with or not towing.
Try www.elementownersclub.com
Old Jan 22, 2009 | 03:50 PM
jeandeau's Avatar
Transmision temperature is different from motor temperature and of critical concern when towing. If you have an auto trans I strongly recommend installing an auxilliary transmision fluid cooler immediately. If it is a light trailer, at least install a temperature guage on the fluid line going to the stock cooler which may be integral with the radiator. Look for a pair of metal hoses coming out of the radiator and put your thermo sensor on the hotter one of the two. See my post and poll on thermometers under Guaging interest forum. If you are content with a simple test you can use a digital indoor outdoor thermometer. If you are interested I'll give details.
Longy
Aug 10, 2013 04:51 AM
Klasse Act
May 5, 2010 04:45 PM
Moltisanti2009
Apr 7, 2009 02:29 AM
michaelfit84
Jan 17, 2009 03:53 AM
rye guy
Jul 26, 2005 01:45 AM
