Coolant Indicator Light Issue
Old Jul 30, 2008 | 09:26 AM
lschiffer's Avatar
What is the experience with the 2008 Fit Sport on its coolant indicator light? Just picked my Fit up a couple of weeks ago and the indicator light (upper right blue) stays on on start-up for 30-45 seconds or so before shutting off. Did not notice it on this long during the first week. Are there problems with the coolant or indicator lights? Plan to have them look at it this Saturday. Thanks.
Old Jul 30, 2008 | 09:54 AM
Fitcapo's Avatar
I don't think so mine has always done that and the light will stay on a little longer when it is cold out or if it is really hot the light isn't there.
Old Jul 30, 2008 | 10:02 AM
yeamans17's Avatar
Theres nothing wrong with your light. Don't waste your time looking into it, the Fit doesn't have a temp gauge, so we have a light to let us know when its up to temp.
Old Jul 30, 2008 | 11:06 AM
Firebat666's Avatar
its just letting you know your motor is not up to normal operating temp. yet, its completely normal, in the winter you will notice it takes FOR EVER to heat up... but its normal dont worry about it
Old Jul 30, 2008 | 12:26 PM
n6nev's Avatar
With my scan gauge ll , I saw that the blue coolant lite is on at coolant engine temp of less than 125 degrees..just drive easy!
Old Jul 30, 2008 | 12:56 PM
Sloto200's Avatar
It's all about reading the owners manual... it tells you in there that it's normal...
Old Jul 30, 2008 | 01:59 PM
select all +1
Old Jul 30, 2008 | 02:04 PM
vtec just kicked in yo's Avatar
It's totally and completely normal. Mine does the same depending on outside temperature. The blue coolant light is just a friendly reminded to drive off gently until the engine is warm.
There is really no need to bother your service department with this.
Old Jul 30, 2008 | 02:17 PM
spreadhead's Avatar
Just as Sloto200 said you can find information on this (and many other features of you car) in the little book that came with it.
Old Jul 31, 2008 | 09:36 AM
Tekki's Avatar
There's kind of a built in temperature sensor!
The engine will idle higher when it's cold, I think it's just around 1500rpm here. When it idles at about 1k, that's when the coolant light will go off.
Generally, when it's fully warmed up, it'll idle at about 750-800rpm unless you're using lights/AC etc which might push it up a bit.
Not really accurate but just something I noticed.
Old Jul 31, 2008 | 04:41 PM
seeremlive's Avatar
This past winter when it was no more than 8 out overnight, I would go 4 blocks with no warm up and it would turn off and I had heat. This is something I noticed right away, as my old Dakota with the V8 would take 3 - 4 miles to do the same thing. If I were you I would have your thermostat checked. It may be stuck open.
Old Jun 3, 2023 | 01:07 PM
magicmoonlove's Avatar
I had the same question. My coolant was low, got it filled but now the light is on and stays on for like 20 seconds or more then goes off. I'm wondering, in the handbook it says see a dealer, but also seeing mixed reviews online that it's normal and blah blah. Could this also mean there's a leak? Thanks so much.
Does it need to be reset some how. Really don't wanna go spend more $$ right now on this but will
absolutely if needed.
Bugzs15
Oct 28, 2013 02:37 AM
chachski90
Sep 11, 2013 09:59 PM
michaelfit84
Jan 17, 2009 03:53 AM
Raaaaaaaaaay.
Jan 13, 2007 06:58 PM
Lalala218
Jun 11, 2006 02:29 PM
