Mild tick on cold 2008 Fit
Old Aug 4, 2008 | 10:23 AM
gbatz's Avatar
Hi all. I received my 2008 Fit about a month ago and couldn't be happier. So far I've put about 1400 miles on it, but yesterday morning I noticed a mild valve tick at startup.
As soon as the engine warmed and the cold coolant light went off the tick went away, this took maybe 3 or 4 minutes. Outside temperature was about 70 degrees, F.
As a note, I drive very conservatively...I think the car's only seen 4000 rpm once.
Anyone else have this happen so early on? I'm hoping it's just a break in thing, I'll probably let it ride until my first oil change then see what Honda has to say. Thanks for your suggestions.
Old Aug 4, 2008 | 11:40 AM
boon4376's Avatar
cracked exhaust manifold?
Old Aug 4, 2008 | 12:02 PM
gbatz's Avatar
Maybe it could be in the manifold, but it I'm pretty sure it's valve train noise. I've had a few old crappy cars with valve noise.
Old Aug 4, 2008 | 01:23 PM
GD3-Fit's Avatar
I <3 SPOON
i don't think you have anything to worry about
mine does it.
it doesn't have anything to do with the manifold.
valve tick is normal
my ap1 ticked
my bb6 ticked
my gd3 ticks
-Ricky
Old Aug 4, 2008 | 04:05 PM
vtec just kicked in yo's Avatar
My car does it too. Completely normal I'm sure. Don't panic.
Old Aug 4, 2008 | 04:58 PM
seeremlive's Avatar
In my experience with Honda's, they all do this until up to temp. This little engine is more pronounced than some other Honda engines. It sounds like a sewing machine. This is nothing to be concerned about, it is normal.
If it gets worse (louder) or becomes a knocking, then you should take it in.
Old Aug 4, 2008 | 05:31 PM
kancerr's Avatar
my fit ticks all the time...even when warm. im assuming its normal. mine has seen redline countless times tho ;p 15k miles so far.
Old Aug 4, 2008 | 05:44 PM
Fa1's Avatar
Fa1
Probably your fuel injectors. It's normal.
Old Aug 4, 2008 | 05:48 PM
doctordoom's Avatar
Supervillain
yeah don't worry about it. it just ticks here and there, sometimes even when already warm.
fujisawa
Oct 22, 2018 11:27 AM
frank438
Jul 12, 2016 11:14 AM
allTRACway
Mar 11, 2016 04:06 PM
gfrobe
Jan 27, 2013 02:44 PM
der Mond
Jul 3, 2011 09:29 AM
