Sponsored by:
Sponsored by: CARiD
hid with halogen high beam
Old Aug 18, 2008 | 11:38 PM
Domo3234's Avatar
i just got a set of hid with halogen high beams. everything works fine but the high beam, when i plug in the high beam prong it stays on with the hid and doesnt turn off. can anyone help me here. do i need a relay harness???
Old Aug 18, 2008 | 11:52 PM
B1str0's Avatar
RubberBabyBuggyBumpers
i got the same setup.. i had a problem with mine but i flipped the harness on the balast and everything worked fine after...
Old Aug 19, 2008 | 12:01 AM
Domo3234's Avatar
i guess ill give it a try thanks
Old Aug 19, 2008 | 12:07 AM
B1str0's Avatar
no prob... if ur harnesses are plug n play then the main line should be the only worry.. other then that try it high beams only and see if they turn off with lows on.. u shouldn't need a relay it could be a fuse or a short as well...
Old Aug 19, 2008 | 12:14 AM
Domo3234's Avatar
when i have the hig beam pluged in it stays on with the HID but when i high beam it, it turns off the hid and keep the high beam on
Old Aug 19, 2008 | 12:52 AM
B1str0's Avatar
im stumped at the moment ill ask my neighbor tomorrow and see what he says...
gabriel0830
Jan 15, 2016 01:06 AM
Mr.Hollow
Sep 1, 2014 07:41 PM
1toughfit
Sep 27, 2013 07:09 AM
stnl619
Dec 24, 2009 12:40 PM
zRollerskate
Jun 18, 2008 04:27 PM
