Wiring to ignition???
Old Aug 23, 2008 | 09:09 PM
joquio's Avatar
I'm planning to took up some J's Tai styled LED lights as my daytime running lights. Where do I tap them in so it lights up when I start the car?
Anyone that can help me?
Old Aug 24, 2008 | 07:10 PM
Fitting's Avatar
Don't they come with on/off switch ?
That way you can still turn them off if you wanted/needed to.
Use the cigarette lighter. Only have 12v when key is in ignition or engine running.
Old Aug 25, 2008 | 03:30 AM
joquio's Avatar
so yeah, they are not actualy "the" J's racing Tai led.
I have to find some where to tap into at the front (engine bay) so cigarette lighter won't work for me.
Old Aug 25, 2008 | 05:09 AM
CuTeBoi's Avatar
Connect to the daylights (the yellow ones) follow the wiring up, making a nice splice with crimp tools, lots of electrical tape, and BAM you are done.
GJ.
To turn them on, just turn your headlights to daylight mode (first click) which doesn't turn on the main lights, just the little yellow lights, and you're done =D
This is how I wired my halos
Old Aug 25, 2008 | 05:29 AM
joquio's Avatar
appriciate your tip. I thought about this already. but if I wire them up like you said when I turn them on the taillights will be lit too I think and I don't want that.
I want them to turn on when I turn on my engine.
Anybody else?
Old Aug 25, 2008 | 05:48 AM
CuTeBoi's Avatar
really? hmm, that is awkward, then a switch would be your best bet. wire a relay to give some positive power from the "cig lighter" or any other source, and when you start up your car, hit the switch, it will turn on your 'daylights' and let you control when they go on and off when the car's ignition is in the on position.
shezzo
Jan 21, 2010 06:54 PM
09blackfit
Nov 20, 2009 05:49 PM
09blackfit
Nov 7, 2009 08:32 AM
09blackfit
Oct 29, 2009 12:51 PM
09blackfit
Oct 29, 2009 10:38 AM
