iso mount or cage mount
Old Sep 29, 2008 | 10:55 AM
metso's Avatar
hi everybody---need some help
i was thinking of buying a used deck that doesnt have the metal mounting cage on it--can a deck be installed in my 07 fit using the factory iso monts???please help
Old Oct 1, 2008 | 11:39 AM
Injundon's Avatar
Both the Metra and Scoche kits come with ISO mounts so it shouldn't be a problem.
Old Oct 2, 2008 | 06:51 AM
x98myers7's Avatar
the factory metal ISO brackets are infinitely superior to the crappy plastic "mounts" that come with the aftermarket kits. what a joke. i actually installed my headunit the typical "DIN" way, but trimmed down the mounting sleeve to allow the rear ISO mount screws to be exposed so i could re-install the OE brackets.
using the OEM brackets allows you to use the two main support screws that hold the OE headunit in place. there's not a single squeak or rattle in my install and it is solid as a rock.
re-use the OE brackets. i can't even imagine using a DIN only mount on the plastic flimsy aftermarket kits.
88self
Jun 13, 2017 11:18 AM
MTLian
May 2, 2016 12:57 PM
allmotormark
Oct 10, 2014 01:16 PM
mxl180
Sep 1, 2014 11:37 PM
hoteldalta
Jul 27, 2011 02:06 AM
