intake heatsoaking???
Old Oct 8, 2008 | 03:24 AM
revd34's Avatar
i don't get what heatsoaking is. it an issue with aftermarket short ram intakes is what i know so far and people go as far as making heat shields for the car. can someone explain it to me? is it bad for my motor or gas mileage?
Old Oct 8, 2008 | 07:15 AM
cojaro's Avatar
"The phenomenon known as "heat soak" occurs when the engine is turned off. At this time, the combustion process is terminated. This terminates the momentum of the crankshaft, which in turn stops the turning of the water pump. As the coolant is no longer being circulated, the engine block and cylinder temperature increase for a period of approximately 3 to 10 minutes, depending on the engine design and additional components."
http://cjbfire.com/Heatsoak.pdf
Google = friend
Old Oct 8, 2008 | 09:35 AM
sterVin's Avatar
Heatsoak is pretty much when things that are around something that gets hot get hot as well. Bad for motor? no. Bad for mileage? you might actually see an increase.
Old Oct 8, 2008 | 05:04 PM
Tofuman's Avatar
I think the OP is referring to heat soak of the intake piping. meaning the ambient underhood temperatures are heating the intake piping and in this case heating the intake air going into the TB.
the oem plastic airbox has less heat soak than most aftermarket piping. but the increase of velocity and volume of air of an aftermarket intake usually will more than negate any loss of power due to heat soak creating a less dense air charge.
Old Oct 9, 2008 | 04:17 AM
revd34's Avatar
thank you guys for answering my question guys. i'm just not sure there is any point in keeping my intake. i don't even floor my car or take it past 3k. i'm going to convert back to stock with a k & n air filter
EXCellR8
Apr 6, 2014 06:53 PM
Rod2Rice
Jul 24, 2008 11:06 AM
Koi
Jun 25, 2008 02:48 PM
Ragnarok0mega
Apr 16, 2007 07:45 PM
dale.spencer@cox.net
Oct 12, 2005 12:30 AM
