anybody swapped Sport Fit 16" wheels for 15" Base model's?
Old Oct 10, 2008 | 08:18 AM
jenhonski's Avatar
After driving both the Sport and Base Fit, I was hoping for a softer ride. It seemed to me that the Base had a slightly softer ride which I attribute to the 15" wheels with higher sidewalls.
The only problem is that I hate to go without Cruise Control. If I could get the Base model with Cruise Control this would solve my problem (anybody know if this is possible--the dealership indicated it wasn't).
If I get the Sport, is swapping out the 16" wheels for 15" steels with higher sidewalls a good move to get a softer ride?
Old Oct 10, 2008 | 09:02 AM
cojaro's Avatar
If you do swap out the alloys for the steelies, you'll be slower and possibly less fuel efficient. Steel is nearly three times as dense as aluminum =\
It probably wouldn't be worth it, IMHO. The Fit is known to have a somewhat bumpy ride as is.
Old Oct 10, 2008 | 09:32 AM
jenhonski's Avatar
Thanks for comments. Sounds like the bumpy ride has more to do with the suspension than with the wheels/tires per se?
Old Oct 10, 2008 | 09:38 AM
Firebat666's Avatar
yes the stiff ride is the suspension, not too much you can do, some people like my self like the stiff ride, it provides more interface with the car, soft cars handle like boats!
Old Oct 10, 2008 | 09:49 AM
Juliane's Avatar
Just underinflate your tires. You will get a reduced gas mileage but you will still have cruise control with a Sport package. at 25 psi, the ride is nice and quiet, and soft. The mileage sucks, but if you want a soft ride, there it is.
Other than that, you might look at a Camry.
Old Oct 12, 2008 | 04:06 AM
FiveFreshFish's Avatar
That's not good advice. Underinflation not only increases fuel consumption, it causes premature tire wear, overheating, and poor handling among other things.
Old Oct 12, 2008 | 10:03 AM
Juliane's Avatar
I know that, but the OP started a thread with a silly question in the first place. I told him he'd get worse gas mileage if he under-inflated but that's no more silly than putting base-package wheels on a Sport...he seems quite concerned with the softness of the ride. I think he shouldn't have a Fit in the first place. Ford Crown Vics have a nice soft ride.
I was being sardonic.
Old Oct 13, 2008 | 12:15 AM
Ah, my sardonicism detector doesn't work too well at 2:00 AM.
Old Oct 13, 2008 | 01:22 AM
feared's Avatar
y not just get aftermarket wheels that r 15" or buy a set of 15" alloys from an 07/08. But make sure to cehck what offset u need n what not.
Old Oct 13, 2008 | 09:12 AM
Juliane's Avatar
It's off-duty then. The union negotiated the hours years ago - sardonicism only works from 9-5.
Irony is still working at 2 a.m. though....
Old Oct 14, 2008 | 01:06 AM
mdm427's Avatar
... sardonicism only works from 9-5.
Take it up a notch to full-fledged smart-assism, it works 24/7. I know.
Old Oct 14, 2008 | 01:10 AM
kylerwho's Avatar
spoon fed
i believe you are mistaken. smart-assism works the grave yard shift. its only dumb-assism that works the 24/365.
Old Oct 14, 2008 | 08:39 AM
Juliane's Avatar
Only when Congress is in session.
Old Oct 14, 2008 | 08:38 PM
kylerwho's Avatar
spoon fed
true. true. take a look at some of the posts around and you will see what personality reigns supreme.
Old Oct 14, 2008 | 09:15 PM
Juliane's Avatar
You're not suggesting that any freaks are dumbasses, are you?? Hey, AFAIK, no one here has registered Mickey Mouse to vote in the upcoming Presidential election! AFAIK, anyway...
All dead people, stand up and be counted!
Old Oct 16, 2008 | 12:29 PM
DrKelso's Avatar
I may be mistaken...but doesn't the GD3 base model come with 14's and the sport come with 15's? Too lazy to run outside and check
filmxj
Sep 21, 2009 04:54 AM
ds61761
Jun 8, 2009 03:30 AM
soboyle
Nov 27, 2008 07:43 AM
jenhonski
Oct 8, 2008 06:35 PM
whitefitsport
Jul 22, 2006 11:59 PM
