Do u guys think it they will fit on my fit?
Old Nov 9, 2008 | 06:48 PM
Draako's Avatar
無限 | Life | PARTS | Handling
Old Nov 9, 2008 | 09:06 PM
Hootie's Avatar
If the wheels have a 4x100 bolt pattern, then yes.
Both generation Fits have the same bolt pattern. The GE8 is rumored of having a Mugen version coming to the US with the Aluminum Wheel XJ installed and the GD3 would also be able to fit either rim because the factory rims are wider that both of those Mugen rims even with a +42 offset.
Old Nov 9, 2008 | 09:12 PM
kylerwho's Avatar
spoon fed
the new ge8 mugen edition released at SEMA comes with these wheels. yes they do work.
Old Nov 9, 2008 | 09:13 PM
Draako's Avatar
thanks for the info , actually i cant read the page cause i cant install the language packages , what bout the NR will they fit?
Old Nov 9, 2008 | 09:14 PM
kylerwho's Avatar
spoon fed
they will fit too. illusive used to have a set on his fit. as long as the offset is in the 40s you should be ok with no rubbing.
Old Nov 9, 2008 | 09:35 PM
Hootie's Avatar
Sure they'll fit on a GD3, but I don't know about the GE8 though. I'm thinking more than likely if Honda didn't change the disc and/or caliper size for the brakes.
Old Nov 9, 2008 | 09:39 PM
kylerwho's Avatar
spoon fed
any wheel that fits the ge8 will definately fit the gd3 but i dont think it works the other way around.
awptickes
Feb 5, 2013 01:53 PM
GE-DZ149
Jul 20, 2012 12:10 AM
KC_fitted
Apr 30, 2012 11:04 PM
OneCamJam
May 23, 2011 02:02 PM
Cl329
Mar 29, 2011 01:49 PM
