Weird Rub/Grind Sound
Old Nov 26, 2008 | 11:25 AM
stlfit's Avatar
Just last night as I was slowing for a stop, I noticed this weird grind/rubbing sound from the front, passenger side wheel area. I was nearly home, so I just pulled into my garage and did a quick look to see if anything was caught (it sounded like it might be) but didn't see anything.
This morning on the way to work, I heard it again, so I tried to eliminate possiblities on the short trip.
1) The sound seems to be independent of acceleration and braking because:
2) It continues after I stop for a few seconds and kind of sounds like something is swinging around something (if that makes sense).
3) It's annoying as hell now that I know it's there.
Any thoughts? Am I providing enough info?
Old Nov 26, 2008 | 05:40 PM
polaski's Avatar
odd. Did you check the belt?
Old Nov 26, 2008 | 06:20 PM
stlfit's Avatar
So today after work, I hopped in my car and started hearing it again as I took off. I had just about relegated myself to making an appointment with the dealer when I decided to test my theory of something being "stuck" and hit the gas a bit harder than normal -- sure enough, it went away.
Probably not the smartest idea in retrospect, but it worked.
If the sound comes back, I'll re-evaluate. But if not, I'll credit the fix to karma.
Old Dec 4, 2008 | 03:35 PM
GD3_Wagoon's Avatar
i remember reading that another Fit owner had the same problem and the noise was coming from a pebble that was wedged between the brake pad and rotor
IIRC, the way he fixed it was similar to your solution except he gunned it in reverse
Old Dec 4, 2008 | 07:05 PM
07fitsport's Avatar
wow...a pebble in the brakes....that sounds like it would be hard to make that happen..
gotta love the FIT
Old Dec 4, 2008 | 09:26 PM
polaski's Avatar
Oh I hate pebbles in the brakes. I get about 3 a year.
Once in the old CRV I was sick and tired of it constantly screeching so I stomped on the brake pedal at 55mph and I could see that sucker fly out in front of the car. It was glowing a bright bright red. Usually I have to take the pads out to make it go away if it's not gone in 2 days or so, that sucks a lot.
Old Dec 6, 2008 | 08:16 AM
Carbuff2's Avatar
I've had "pebbles in the brakes" on several of my cars (not all of them Hondas). My 81 Civic had that several times.
Yeahhhok
Jun 21, 2018 12:31 AM
Yeahhhok
May 31, 2018 11:43 PM
kaikou
Oct 22, 2015 03:19 AM
toomuchjoy
Jun 10, 2012 09:31 AM
mikejet
Nov 6, 2010 09:02 AM
