bi-xenon retrofit flickering...
Old Nov 29, 2008 | 11:37 PM
gn-it&rn-it's Avatar
I did the fx-35 bi-xenon retro, thanks to smeisters DIY, a little over a year ago. The problem is, recently the drivers side bulb flickers alot. Also, normally it takes the bulbs 30-60 seconds to warm up to normal temp(4300k), but now when you turn the lights on, the driver side is instantly at temp. Any clues??? i know the bulbs are supposed to last a long time, but i dont know how long these bulbs have been in service from the time i grabbed 'em off E-bay. (they came with the projectors)
P.S. I've had a problem with the passenger side before, due to an inefficient grounding( i was in a hurry). So i dont think that my problem noted above is with the ground, because either the light works, or it doesn't right?
Old Dec 1, 2008 | 07:28 PM
any clues??? bump..
Old Jan 11, 2009 | 10:19 PM
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
could be a bad connection between ballast and bulb (i had similar prob)
only real way to find out is to do it systematically i.e. try switching bulbs L with R
if flickering is on same side = bad ballast (or bad connection on the left side)
if flickering moves to passengers side = bad bulb
i know it might be a lot of work but it's the only way to make sure
why don't u let the "paper people" out lol (that is THE BEST sig EVER)
Old Jan 18, 2009 | 09:45 PM
SFactor2's Avatar
wish it were that easy
intermittent electrical problems r the trickiest to fix
u have a bad connection somewhere or the ballast is going
Old Jan 19, 2009 | 12:39 AM
Fit of RAGE's Avatar
ballast is going.
cKranez
Aug 10, 2009 11:48 AM
Luichenwai
May 26, 2009 03:19 AM
qbmurderer13
28
Feb 5, 2009 05:42 PM
xonexlifex
Oct 12, 2008 12:27 PM
YeeFit
Mar 28, 2008 11:28 PM
