how to put the extended wheel stud on a fit
Old Jan 28, 2009 | 07:20 PM
JDMfit_2008's Avatar
hi guys i need ur help fast just wondering how u can put the extended wheel stud by doing if by ur self so and opinions are open thanks guys
Old Jan 28, 2009 | 07:57 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
A search helps.
Youll need a slide hammer and air tools.
Its a lot harder than you think. The front hub needs to be taken apart as its pressed together. Remove the caliper, caliper braket, rotor, axle nut, all that.
Before you put it all back together youll need to re-pack the wheel bearings. Air tools come in now. To press the hub together an impact gun will need to be used on the axle shaft threads. Not 100% sure if this will work. This is the only way I can think of doing it at home?
Rears are easier, yet still require a lot of parts to be removed first.
Old Jan 29, 2009 | 01:31 AM
Im|Inside|Fit's Avatar
AHHH NOO!!!! i wanted to get them and post them cuss i havent seen a fit on here that has it yet... none that ive seen GRR! you beat me to it oh well let me know how it went good luck =)
EDIT:
i was just being quiet and not letting anyone know about it but dang it you beat me =/ =P
Old Jan 29, 2009 | 02:08 AM
kylerwho's Avatar
spoon fed
that is a good idea ray but i think you will strip the threads if you try the air gun method cause that hub is pressed on really good. i have not tried this but i looked into it and it looks nearly impossible without a press. correct me if im wrong though.
Old Jan 29, 2009 | 02:28 AM
Tork's Avatar
Havent done it on a honda, but I have done it on 3 Nissans.
Not going against Ray or Kyler, they may know better.
I just turned the hub until the back of a stud was by the access hole in the splash shield.
Used a 1" X 10" long aluminum rod and a sledge hammer and pounded it out, now maybe the 100MM bolt circle wont allow that. If you can look from the back and see the stud head, that would give you a clue. Only disassembly was removing caliper and disc or drum
I'd go to Helm and pay the $10 for a 3 day online pass to all the service manuals
Old Jan 29, 2009 | 02:56 AM
got any pics
just wondering if u guys have pics on the step by step process thanks for helping guys
Old Jan 29, 2009 | 09:03 AM
Tork's Avatar
I love Google, found this in 2 minutes
It's 4 civic and 100MM bolt pattern, this ought to be very close to what you need to do.
http://www.hondacivicforum.com/forum...ad.php?t=19175
Old Jan 29, 2009 | 09:39 PM
thanks
thanks for the pics but i need the one for extended wheel stud instollation but iam gonna try it though but give me some more guys plsssss thankss guysss
Old Feb 4, 2009 | 02:18 AM
MWUAHAHAH! i jstu got done installing my extended studs =DDD well i did do it by myself i have my friend help me =) its hard if you dont have the right tools.. itll take you forever to put on... my buddy and i did it in 2 hours! lol we were at his work place to where all the tools and such are at too but still it was hard... well its not that its hard its jsut time consuming... sorry i cant help you much but to let you know that it might take awhile and you might want some help to do this... i would take some pictures and share it but i dont have a digital camera =/ but overall after all that pain in the butt its well worth it
its been a long time since youve posted this did you do it yet? =)
Phoenician
Oct 5, 2016 12:08 AM
Vash
Sep 15, 2016 09:40 AM
Rollerboots666
Apr 10, 2014 12:02 AM
teamkitty
Dec 5, 2010 03:57 PM
boyetssilverfit
Feb 13, 2007 08:24 PM
